Debuging OpenMP TASK constructs
jansson
HI,
I try to locate a problem in my OpenMP version of a old FORTRAN program.
I use a TASK construct going through a linked list to parallelize.
!$OMP TASK default(none) ...
lots of code
!$OMP END TASK
I find there is a problem when using many cores*, so I try OMP_SET_NUM_THREADS(1) just before entering thisparallel region, and then the code works. But if I use a CRITICAL section to narrow down the problem the program fail even when its the whole TASK region.
!$OMP CRITICAL(NAME)
lots of code
!$OMP END CRITICAL(NAME)
!$OMP END TASK
Why might this be?
Any suggestions going forward?
I already tried Inspector and parallel:debug looking for overlapping mem access, with no success...yet...
I guess ORDERED do not work for TASK.
Magnus
*using 8 threads on my 4+4 hyper threads CPU.
