29376 Discussions
Default Endian convention change between XE15 and XE16
OP1
New Contributor III
After installing both XE15 and XE16 on one of our Linux clusters, we realized that the simple code here
real(kind=8)::a
a=123456789d0
open(10,file='bin.dat', form='unformatted')
write(10) a
close(10)
end
does not produce the same output (byte order) in the XE15 and XE16 environments.
Has a default value for the FORT_CONVERT.ext, FOR_CONVERTn and/or F_UFMTENDIAN environment variables changed from 15 or 16? Or does this point at an error in our installation?
Endian change? Absolutely not! Do you have any of those environment variables set?
OP1
New Contributor III
Thanks Steve - I wanted to exhaust all options here, I agree this hypothesis was a one in a million shot; are there options others than the one indicated above to change the endian convention? It is puzzling because we are just loading/unloading the module for XE16 (reverting back to XE15) and we see the change between the two.
There's also FORT_CONVERT_ext (not to be confused with FORT_CONVERT.ext). Plus CONVERT= on OPEN, OPTIONS and -convert on compile. Also look for ifort.cfg files that specify defaults. Ask for a listing file (-list) and see what it shows for the convert option.
