Default file in the GetSaveFileName
meistrv
Is it possible to fill the "File Name" field in the "Save As" common dialog box by some default name? I couldn't find anything like that within the openfilename structure.
Thanks for help
Vit
Jugoslav_Dujic
Valued Contributor II
It's the lpstrFile member, i.e. the same field you get the name as the output. If it's non-blank (non-char(0)), it will appear in the dialog.
Jugoslav
