The following after compiling with 12.1.1 explodes at runtime with an access violation that seems unwarranted. 12.0.5 doesn't appear to have an issue.
[fortran]MODULE SomeTypesAndAFactoryForThoseTypes
IMPLICIT NONE
PRIVATE
TYPE, ABSTRACT, PUBLIC :: ParentType
INTEGER :: a = 1 ! Note default initialization.
CONTAINS
PROCEDURE(parent_Proc), DEFERRED :: Proc
END TYPE ParentType
ABSTRACT INTERFACE
SUBROUTINE parent_Proc(obj)
IMPORT :: ParentType
IMPLICIT NONE
CLASS(ParentType), INTENT(OUT) :: obj
END SUBROUTINE parent_Proc
END INTERFACE
TYPE, PUBLIC, EXTENDS(ParentType) :: OneType
INTEGER :: b
CONTAINS
PROCEDURE :: Proc => one_Proc
END TYPE OneType
TYPE, PUBLIC, EXTENDS(ParentType) :: TwoType
REAL :: c
CONTAINS
PROCEDURE :: Proc => two_Proc
END TYPE TwoType
PUBLIC :: Factory
INTERFACE Factory
MODULE PROCEDURE Factory_
END INTERFACE Factory
CONTAINS
SUBROUTINE Factory_(str, obj)
CHARACTER(*), INTENT(IN) :: str
CLASS(ParentType), INTENT(OUT), ALLOCATABLE :: obj
SELECT CASE (str)
CASE ('one')
ALLOCATE(OneType:: obj)
CASE ('two')
ALLOCATE(TwoType :: obj)
CASE DEFAULT
! Just leave unallocated
END SELECT
END SUBROUTINE Factory_
SUBROUTINE one_Proc(obj)
CLASS(OneType), INTENT(OUT) :: obj
obj%a = 1
obj%b = 2
END SUBROUTINE one_Proc
SUBROUTINE two_Proc(obj)
CLASS(TwoType), INTENT(OUT) :: obj
obj%a = 10
obj%c = 30.0
END SUBROUTINE two_Proc
END MODULE SomeTypesAndAFactoryForThoseTypes
PROGRAM DearIntelDevelopersForTwelvePointOneYouOweMeACaseOfBeer
USE SomeTypesAndAFactoryForThoseTypes
IMPLICIT NONE
CLASS(ParentType), ALLOCATABLE :: obj
CALL Factory('one', obj)
IF (.NOT. ALLOCATED(obj)) STOP
CALL obj%Proc
END PROGRAM DearIntelDevelopersForTwelvePointOneYouOweMeACaseOfBeer
[/fortran] [plain]>ifort /check:all /warn:all /standard-semantics /traceback ItsFridayAndImThirsty.f90 Intel Visual Fortran Compiler XE for applications running on IA-32, Version 12.1.1.258 Build 20111011 Copyright (C) 1985-2011 Intel Corporation. All rights reserved. Microsoft Incremental Linker Version 10.00.40219.01 Copyright (C) Microsoft Corporation. All rights reserved. -out:ItsFridayAndImThirsty.exe -subsystem:console -incremental:no ItsFridayAndImThirsty.obj >ItsFridayAndImThirsty.exe forrtl: severe (157): Program Exception - access violation Image PC Routine Line Source ItsFridayAndImThi 008F13E5 _SOMETYPESANDAFAC 55 ItsFridayAndImThirsty.f90 ItsFridayAndImThi 008F10DA _MAIN__ 73 ItsFridayAndImThirsty.f90 ItsFridayAndImThi 0091F923 Unknown Unknown Unknown ItsFridayAndImThi 0090AF1D Unknown Unknown Unknown kernel32.dll 761AD309 Unknown Unknown Unknown ntdll.dll 76F716C3 Unknown Unknown Unknown ntdll.dll 76F71696 Unknown Unknown Unknown[/plain]
Thanks - I have passed this along to the developers. The issue ID is DPD200176585.
Unfortunately, fixing this properly required a complicated change that we don't want to put into a minor update. It is fixed for the next major release.
Thanks. I'm still thirsty, but have moved off beer and onto wine. Any thoughts as to when I might be able to download the next major release crack the screw top on the semillon that's hiding up the back of the fridge?
Your wine will need to age some more months, but you'll be able to enjoy it this year.
