Default value of dimensions
Nima_Khorsandnia
Hi Steve,
I have upgraded my previous code to new intel fortran and is working properly but I have an issue. The default value of integer dimensions is-842150451 and real numbers is-6.277438562204192E+066, which are the lowest bound. In older versions, the default value was zero. Is there any way that I can make all my dimensions zero or I should do it one by one in the code?
Looking forward to hearing from you soon.
Warmest regards,
Nima
Les_Neilson
Valued Contributor II
If I understand correctly you mean scalar variables (not "dimensions") and you have code which relied upon those variables being automatically initialised to zero.
I highly reccommend that youchange your code to explicity initialiseyour variables to zero (or some other relevant value), so that it is then obvious to a future reader of the code (which may be yourself) what is happening.
But there us a compiler setting /Qzero to initialise local scalars (NOT ARRAYS).
This is non-standard and non-portable and should not be relied upon.
Les
TimP
Programs which rely on /Qzero often also rely on /Qsave and on avoiding certain modern syntax and compiler optimization features. Those options may help as temporary stop-gaps while correcting other errors.
