29627 Discussions
Define a character function with variable length
Zorrilla__David
I'm trying to programming a function with variable length arguments and variable length retuned value. I try this:
FUNCTION REPLACE_CHAR(STR,CHIN,CHOUT)
    IMPLICIT NONE
    CHARACTER(LEN=*) :: STR
    CHARACTER(LEN=LEN(STR))::REPLACE_CHAR
    CHARACTER(LEN=1)::CHIN,CHOUT
    INTEGER(KIND=4)::I
    REPLACE_CHAR=STR
    DO I=1,LEN_TRIM(STR)
        IF (STR(I:I)==CHIN)THEN
            REPLACE_CHAR(I:I)=CHOUT
        ENDIF
    ENDDO
    RETURN
END FUNCTION
But although I have no error in compilation of this functions, I have an error when I call this functions from another:
CHARACTER(LEN=LEN(STR))::REPLACE_CHAR,STR1
STR1=REPLACE_CHAR(STR,'\','/')
I also try this (with allocate):
    IMPLICIT NONE
    !CHARACTER(LEN=*) :: STR
    CHARACTER(LEN=:),ALLOCATABLE :: STR, REPLACE_CHAR
    INTEGER(KIND=4)::I,LENGTH
    LENGTH=LEN(STR)
    ALLOCATE(CHARACTER(LEN=LENGTH) :: REPLACE_CHAR)
    REPLACE_CHAR=STR
        ENDIF
    ENDDO
    RETURN
END FUNCTION
But I have the same error when I call this function.
How can I do this?
Thanks in advanced
Arjen_Markus
You do not indicate what the error is, but judging from the way you are declaring and using the function, I suspect that you did not put it in a module.
When you do, there is no need for the explicit declaration of replace_char. This is taken care of by the use statement for the module. Moreover, the module provides exactly the right information for the compiler. So my advice is to put the function in a module and then use that.
The "allocatable" version is more flexible, because it may be that at some point you are going to replace a string by a longer string and will not know in advance how long the resulting string should be. But for now, the first version ought to do it.
andrew_4619
module rs
    implicit none
    contains
        CHARACTER(LEN=:), ALLOCATABLE :: REPLACE_CHAR
        CHARACTER(Len=*)              :: STR
        CHARACTER(LEN=1)              :: CHIN, CHOUT
        REPLACE_CHAR = STR    ! automatic allocation of REPLACE_CHAR
        DO I = 1 , LEN_TRIM(STR)
            IF (STR(I:I) == CHIN)THEN
                REPLACE_CHAR(I:I) = CHOUT
            ENDIF
        ENDDO
    END FUNCTION
end module rs
program main
    use rs, only: REPLACE_CHAR
    implicit none
    character(:), allocatable :: str1
    character(80)             :: str
    str = 'c:\testing\testing\123'
    print *, str
    STR1 = REPLACE_CHAR(STR,'\','/')
    print *, str1
    print *, REPLACE_CHAR('c:\testing\testing\1234','\','/')
end program main
Zorrilla__David
Thanks. I have just tried and works but there's a way to do this without a module definition. I have been reading this post (https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/280657) ;and it seems that you can do this without a module.....?
andrew_4619
Why the aversion to modules? They are the best thing in Fortran. You would need to supply and interface to the routine where it is used otherwise. A module does that automatically.
Zorrilla__David
I have no problem with modules, but if I use a module I have to "remember" to call it (use...) and if I don't use a module I define these functions/subroutines in another file (library.f90, for example) and can call this routines from anywhere.
In fact, this subroutines work for me in early version of intel fortran by using   CHARACTER(LEN=*) in the definition of the routine, and I call them without using "USE" statement or defining variables with "ALLOCATE" statement.
Anyway thaks a lot for your help. I think you are a good team in fortran programming.
Thaks
Arjen_Markus
But without modules you have to rely on your getting the argument list correct yourself. With modules the compiler can check them, so that errors in at least the number and the types of the arguments are caught at an early stage. I find that a very small price to pay - merely remembering to add a single line of code.
Beware of CHARACTER(len=*) functions: they were introduced in FORTRAN 77, but their semantics are definitely surprising.
Zorrilla__David
Yes, you have convince me about using modules and allocatable statements (in fact I force my student to use these statements). I am now "reprogramming" my routines.
Another question about this topic, could I have some problems in linux compiler or maybe I have to change something in the routine (because I am programming in windows but I'd like to compiler this software in linux too).
Arjen_Markus
As long as you use standard Fortran the code should be quite portable. I wouldn't worry about that. The only thing you may run into if you are using cutting-edge features (e.g. the latest additions to the language in Fortran 2008), then some compilers may not actually support that. But other than that, it should be fine.
