Delete to recycle bin
kompute
Anyone kind enough to point out what is wrong with the alignment in [shFileOpStruct]? Can't seem to get the program to work.
program
recycle_bin_test
use
ifwin
type
shFileOpStruct
sequence
integer*4
:: hWnd = 0 !long
integer*4
:: wFunc = 0 !long
integer*4
:: pFrom = 0 !string
integer*4
:: pTo = 0 !string
integer*2
:: fFlags = 0 !integer
integer*4
:: fAnyOperationsAborted = 0 !long
integer*4
:: hNameMappings = 0 !long
integer*4
:: lpszProgressTitle = 0 !long
end
type shFileOpStruct
type(shFileOpStruct) SHFileOp
character
*1024 SHFileOpFilename
integer
SHFileOpResult
SHFileOp%wFunc = FO_DELETE
SHFileOpFilename = "tempfile.txt"//
char(0)//char(0)
SHFileOp%pFrom =
loc(SHFileOpFilename)
SHFileOp%fFlags = FOF_ALLOWUNDO
SHFileOpResult = SHFileOperation(SHFileOp)
end
ggveldkamp2
I think you can just use:
TYPE (T_SHFILEOPSTRUCT) :: shFileOpStruct
No need to define the struct yourself.
kompute
Thanks! The program works with a slight bug. I can't find the deleted files in the recycle bin. Any ideas? Is it because I did not specify the directory location?
The code as follows:
program
recycle_bin_test
use
ifwin
type
(T_SHFILEOPSTRUCT) :: SHFileOp
character*1024 SHFileOpFilename
integer
SHFileOpResult
SHFileOpFilename = "New *.txt"//
char(0)//char(0)
SHFileOp%pFrom =
end
ggveldkamp2
I am not sure, maybe you need to use the FOF_MULTIDESTFILES flag and/or set SHFileOp%pTo=0.
kompute
Thanks for your help. The problem is that the full path must be specified in order for the undo to work.
The final code is as follows:
program
recycle_bin_test
use
ifwin
implicit none
type
(T_WIN32_FIND_DATA):: WFD
type
(T_SHFILEOPSTRUCT):: SHFileOp
character
(LEN=1024) SHFileOpFilename
character
(LEN=MAX_PATH) path
integer
path_len
integer
file_len
integer
SHFileOpResult
integer
hWFD
integer
(SINT) :: ret
logical
bSt, bDummy
file_len = GetModuleFileName (NULL, path,
len(path))
path_len =
scan (path, '', back=.true.)
ret = MessageBox ( &
GetForegroundWindow(), &
! Handle to window
trim(path(1:path_len))//char(0), & ! Text (don't forget C-string if "string" is used)
"Full path of executable file"C, &
! Caption for title bar
MB_ICONINFORMATION + MB_OK)
! Type flags
write
(*,*) "Path: "//path(1:path_len)
bSt = .TRUE.
hWFD = FindFirstFile("New *.txt"//
char(0)//char(0) , WFD)
do
while (hWFD /= INVALID_HANDLE_VALUE .AND. bSt)
SHFileOp.wFunc = FO_DELETE
SHFileOpFilename =
trim(path(1:path_len))//"New *.txt"//char(0)//char(0)
SHFileOp.pFrom =
SHFileOp.fFlags = FOF_ALLOWUNDO + FOF_NOCONFIRMATION + FOF_MULTIDESTFILES
bSt = FindNextFile(hWFD, WFD)
end do
! illustrate alternative coding method
bSt = .TRUE.
hWFD = FindFirstF ile("Old *.txt"//
do
SHFileOpFilename =
trim(path(1:path_len))//"Old *.txt"//char(0)//char(0)
SHFileOp%pFrom =
SHFileOp%fFlags = FOF_ALLOWUNDO.or.FOF_NOCONFIRMATION.or.FOF_MULTIDESTFILES
end do
end
