29656 Discussions
Derived type constructor for extended types does not initialize all fields
bpichon
Dear Fortran,
I have some derived types, types extended from a root (astract) type.
I define (scalar) variables using their constructors.
When the type is "simple" types (e.g. Point_2D : real :: x, y) it is Ok
But, when the type is more complicated (e.g. Circle : Point_2D and real :: radius)
  the field radius is not intialized.
More strange (see output file) if the type is like ( Rectangle : Point_2D , real: h,w) the
 h-field is initialized with the value of w-field and, therefore, w_fild not initialized
See details and program in attached files.
(Of course, if the fields are defined field by field it is Ok but more tedious to do)
The source you attached has several errors and won't compile.  Please fix these errors and attach again.
bpichon
Oupps !!
Sorry, here is the good one ...
Bernard
Pour compiler version is : ifort (IFORT) 13.1.0 20130121
Is the a.out useful for you ??
bpichon
This line is not beautiful : Type(Point_3D) :: P3 = POINT_3D(12.0,13,100.0)
I prefer ;  Type(Point_3D) :: P3 = POINT_3D(12.0,13.0,100.0)
Thanks - I can reproduce the problem and have escalated it as issue DPD200241863. I will let you know of any progress.
This problem has been fixed for a release later this year.
