29636 Discussions
Derived type containing an allocatable component in input/output lists
victorht
Dear All,
Steve is so helpful here and I can't help asking another question :-)
ifort has a restriction that Variables containing ultimate allocatable array components are forbidden from appearing directly in input/output lists.
[bash]        type a
          integer, allocatable :: a1(:)
        end type a
        type(a), allocatable :: b(:)
        write(*,*) 'b = ', b
[/bash]
I am wondering is it possible that the future version of ifort will remove this restriction? If not, what is the better way to write out or read in a derived type containing allocatable components? Our derived types are very complicated and contain many components and sub-components, so it will be very painful to explicitly list all the components and sub-components in input/output list.
Thank you very much for your kind help!
Victor
This is a restriction in the standard. The standard way of dealing with this is a "user-defined derived type I/O procedure", a feature not yet implemented in Intel Fortran and one I don't expect to see for a while.
The wording in the standard is this:
9 If a list item of derived type in a formatted input/output statement is not processed by a defined in-
10 put/output procedure, that list item is treated as if all of the components of the list item were specified
11 in the list in component order; those components shall be accessible in the scoping unit containing the
12 input/output statement and shall not be pointers or allocatable.
13 If a derived-type list item is not processed by a defined input/output procedure and is not treated as a list
14 of its individual components, all the subcomponents of that list item shall be accessible in the scoping unit
15 containing the input/output statement and shall not be pointers or allocatable.
victorht
Dear Steve,
Thank you very much for your detailed explanation!
I am wondering are there any differences regarding the treatment of derived type containing an allocatable component in a formatted input/output statement vs. in an unformatted statement?
Thanks again for all your help!
Victor
Yes, but it doesn't help you. The standard says that if the derived type or any of its subcomponents are to be processed by a user-defined I/O procedure, then it is treated as the list of components but none of those that are not processed by a user-defined I/O procedure may be pointer or allocatable. Otherwise, the derived type is treated as a single entity, but none of the subcomponents may be pointer or allocatable.
victorht
Thank you again very much, Steve!
Victor
