29383 Discussions
Detected operating system is not supported
jarfa_f60
Hi all
I try to install l_fcompxe_intel64_2011.6.233.tgz on fedora 14 but I have faced with this error :
Step no: 1 of 6 | Options > Missing Optional Pre-requisite
Detected operating system is not supported. Supported operating systems for this
release include:
- Red Hat Enterprise Linux* 4.0, 5.0, 6.0 (IA-32/Intel 64)
- Fedora* 15 (IA-32/Intel 64)
- SuSE Linux* Enterprise Server* 10.x, 11.0 SP1(IA-32/Intel64)
- Asianux* Server 3.0, 4.0 (IA-32/Intel 64)
- Ubuntu* 10.04 LTS, 11.04 (IA-32/Intel 64)
- Debian 6.0 (IA-32/Intel 64)
1. Finish with prerequisites and continue installation [default]
2. Back to Pre-requisite summary dialog
h. Help
b. Back to the previous menu
q. Quit
how can I solve this problem ???
thanks
mecej4
The release notes for the 12.1 compiler state the following prerequisite:
One of the following Linux distributions (this is the list of distributions tested by Intel;
other distributions may or may not work and are not recommended
o Fedora* 15
You may do one of the following
o Update to Fedora 15 or later before installing Intel Fortran
o Install an older version of Intel Fortran compatible with Fedora 14
o Ignore the installer's complaint, go through with the installation, and see whether the compiler works to the extent that it meets your needs, at least.
Ron_Green
just choose Option 1 (default), ignore it and move on. FC14 will work fine, the installer is not perfect.
ron
