Detecting NaNs
AONym
New Contributor II
I want my Fortran pgm to cause an exception, and have the debugger get control, when a real variable is set to NaN or infinity. I have fpe:0 in the command line, and I set the FP control word using
CALL GETCONTROLFPQQ (controlword)
controlword=IAND(controlword,INOT(FPCW$INVALID))
CALL SETCONTROLFPQQ (controlword)
testNaN=x'7FF8000000000001' ! signalling NaN
ftol=testNaN
xtol=testNaN+1d0
testNaN, ftol and xtol are declared REAL(8).
But I still don't get an exception on any of the last 3 lines.
What do I need to do to get these exceptions?
Did you compile with /fpe:0 specified?
AONym
New Contributor II
Yes. I both had fpe:0 in the command line, and the modification of the floating control word in the pgm.
FWIW, this is a mixed C++ - Fortran pgm, with the C++ the "main project" and the Fortran a library.
g_f_thomas
Irrespective of /fpe:n, you're overriding it to allow NaN's to be generated and thenyou want the debugger to halt when one is produced. You'll have to place a breakpoint when one occurs for the debugger to catch this since it's not a bug by design. BTW, is controlword of type integer(2)?
HTH,
Gerry T.
AONym
New Contributor II
HTH,
Gerry T.
Yes, controlWord is declared INTEGER(2), though that should not matter as long as it's >=2 bytes in size.
I want the debugger to stop at the time the Nan or infinity is generated. Therefore I can't place a breakpoint, because I don't know where to put it. At the end of a long computation, a result is displayed as NaN; the question is, where in that computation was the initial NaN generated?
g_f_thomas
Use /fpe:0 in conjunction with traceback.
AONym
New Contributor II
As I said, I am using fpe:0. I also have traceback enabled. I do not get debugger control when a NaN appears.
William_H_Intel3
In the code snippet you posted, there is nothing to consume the result of the addition. If that is the real code you have, try adding a print statement to actually use the value. I'm just guessing the compiler may have thrown away the operation that would trip the exception since the result is never used.
Hope this is helpful...Bill
