29376 Discussions
Detecting OUTPUT_UNIT and ERROR_UNIT 'equivalence'.
OP1
New Contributor III
Is there a way to detect the 'equivalence' of OUTPUT_UNIT (which is 6) and ERROR_UNIT (which is 0) when both are connected to the console, to avoid duplicate output there?
In other words, considering the code
WRITE(UNIT=OUTPUT_UNIT,FMT='(A)') 'Some text'
WRITE(UNIT=ERROR_UNIT,FMT='(A)') 'Some text'
can we avoid having a duplicate output of 'Some text' when using the console? (when the console is not used, it's okay and in fact desired to have separate output to stderr and stdout).
Do an INQUIRE by unit on both units, asking for NAME=. Compare the strings.
OP1
New Contributor III
It works beautifully, neat trick! Thanks Steve.
