Determining file length
alexismor
Hi everyone,
I was wondering if there was an easy way to do this. I wan't to read some data from a file, and input it into an allocatable matrix. To do this I need to know how many lines there are in the file, so that I can allocate the right size to the matrix.
For example, suppose that I have a file called data.dat which has the following data:
1 2 3
4 5 6
7 8 9
I would like to know that there are 3 lines, so that I can allocate my array appropriately. Is there an easy way to do this?
Alexis
It's pretty easy to get how many bytes are in a file (GETFILEINFOQQ). But "lines"? unless you know that each line is the same number of bytes, you will have to read through the file and count the lines yourself.
Most applications like this require that the size of the data be specified in a prior record first.
jim_dempsey
Or in a final last record.
e.g. FileSize-n bytes is a record containing
Signature
File information (array dimensions in this case)
The Signature is used to verify if the file is corrupt.
Jim Dempsey
cacciatore
Alexis
By the example you gave:
1 2 3
4 5 6
7 8 9
it seems to be a sequential formatted ASCII file. In this case I use:
open(unit=3, file='data.txt',form='formatted')
nlines=0
do while(.not.eof(3))
read(3,*)
nlines=nlines+1
end do
rewind(3)
allocate(matrix(nlines,...))
do i=1,nlines
read(3,fmt='....')matrix(i,..)
end do
Don't know if read(3,*) would work with binary sequential files.
Geraldo
