29376 Discussions
Diagnostics of kind mismatches of intrinsics (e.g. MIN) could be improved
Harald
the standard conformance diagnostics can sometimes be confusing.  Example:
[fortran]
subroutine foo (i, k, m)
  integer    :: k
  integer(1) :: i, m(3)
  k = min (k, i)           ! Useful    warning
  k = min (k, maxval (m))  ! Confusing warning
end subroutine foo
[/fortran]
%  ifort ifort-confusing.f90 -stand -c
ifort-confusing.f90(4): warning #7374: F2003 standard requires all arguments be of the same type and same kind type parameter.
ifort-confusing.f90(5): warning #7374: F2003 standard requires all arguments be of the same type and same kind type parameter.   [MAXVAL]
(a) One might mention the name of the intrinsic affected (here: MIN);
(b) MAXVAL is not the problem, it just happens to be used in the code... :-)
Anonymous66
Valued Contributor I
Hello Harald,
I have filed a feature request to improve the diagnostic mesage for this case. The issue number is DPD200243638
Annalee
