Dialogs
kgcole
Hello, I'm new around this forum, and recently downloaded an evaluation version of Visual Studio. I've been trying to make my own Dialog process with a Fortran source, and haven't been successful. I've used DLGINIT, and DLGMODAL to display my created dialog, but the dialog doesn't show. I've got the proper resource.h and resource.fd files generated, but still doesn't show. If I included the short source code here, would someone be able to tell me what I'm missing that is causing the problem? - - Kevin
ZlamalJakub
New Contributor III
Please post your project (all significant files *.vfproj, resources, source code)
Jakub
kgcole
Thanks Jakub...it's very simple as I'm a novice...my source file (Source1.f90):
PROGRAM PLAYRUS
implicit none
INTEGER lret
IF(lret) THEN
CALL ENVIRON
END IF
END
SUBROUTINE ENVIRON
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_ENVIRON@16' :: ENVIRON
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'ENVIRON' :: ENVIRON
!DEC$ ENDIF
use user32
use kernel32
use iflogm
use ifwinty
implicit none
integer(SINT) nCmdShow
integer(BOOL) bret
include 'resource.fd'
type (dialog) gdlg
type (T_MSG) mesg
LOGICAL lret
lret = DLGINIT(DrillCmd, gdlg)
lret = DlgModeless(gdlg, nCmdShow)
PAUSE
END SUBROUTINE ENVIRON
....my resource.h:
//{{NO_DEPENDENCIES}}
// Microsoft Visual C++ generated include file.
// Used by Resource1.rc
#define IDD_DIALOG1 101
#define DrillCmd 101
// Next default values for new objects
#ifdef APSTUDIO_INVOKED
#ifndef APSTUDIO_READONLY_SYMBOLS
#define _APS_NEXT_RESOURCE_VALUE 102
#define _APS_NEXT_COMMAND_VALUE 40001
#define _APS_NEXT_CONTROL_VALUE 1000
#define _APS_NEXT_SYMED_VALUE 101
#endif
#endif
...my resource.fd
! resource.fd generated from resource.h
integer, parameter :: IDD_DIALOG1 = 101
integer, parameter :: $_WIN32 = 1
integer, parameter :: DrillCmd = 101
ZlamalJakub
New Contributor III
I do not know how you created your resource files but there are only definitions of constants not dialog itself (resource.rc).
I do not use intel build in dialog routines and did not found any example in samples of intel fortran, but you can try to look to samples (in directory)
"c:\Program Files (x86)\Intel\Compiler\11.1\060\Samples\en_US\Fortran\Dialog.zip"
I have found some example in old CVF compiler and prepared project to you, look at it and learn how to do.
Jakub
kgcole
Thanks, Jakub, I'll look the samples over..... - - Kevin
