29649 Discussions
Differences found in executable from code compiled with v11.1 and v12.0
Gerald_Duff
I have moved to XE composer 2011 and found out that the results from my code are differents from the one computed with v11.1
The problem comes from the new compiler optimization :
v11.1, no optimization : OK
v11.1, /O3 : OK
V12.0, /O3 : Wrong
The involved loop is the one below, a "write" statement correct the problem.
do ispeed=1,nspeed
if (ispeed == num_speed_temp(inss,iroute)) then
prob_speed(ispeed, inss,iroute)= prob_speed(ispeed, inss,iroute) + a
!write(*,*) !necessary to get correct results
end if
end do
Anyone knows how to avoid such error and still benefit of some optimization for the other part of the code ?
We would need to see the actual program and be able to compile and run it to comment. Often a problem that "goes away" when a WRITE is added is caused by a reference to uninitialized memory. The actual error can be unrelated to the code you added.
Gerald_Duff
Thanks for the answer, it certainly had something to do with uninitialized memroy, changing a fixed size array into an allocatable array have solved the problem.
