29642 Discussions
Different behavior of integer pointer and class(*) pointer with an integer target
Ben_Lauwens
Following code results in an error:
program test20100518
implicit none
class(*), pointer :: first
class(*), pointer :: second
allocate (first, source = 150)
second => first
deallocate (second)
end program
source /opt/intel/Compiler/11.1/072/bin/ifortvars.sh intel64; ifort -c ../src/test/test20100518.f90
source /opt/intel/Compiler/11.1/072/bin/ifortvars.sh intel64; ifort -o ../simulator *.o
source /opt/intel/Compiler/11.1/072/bin/ifortvars.sh intel64;./../simulator
forrtl: severe (173): A pointer passed to DEALLOCATE points to an array that cannot be deallocated
Image PC Routine Line Source
simulator 000000000046D92D Unknown Unknown Unknown
simulator 000000000046C435 Unknown Unknown Unknown
simulator 0000000000441E80 Unknown Unknown Unknown
simulator 000000000042FE3A Unknown Unknown Unknown
simulator 0000000000412C80 Unknown Unknown Unknown
simulator 000000000040319B Unknown Unknown Unknown
simulator 000000000040308C Unknown Unknown Unknown
libc.so.6 00002B407E291C4D Unknown Unknown Unknown
simulator 0000000000402F89 Unknown Unknown Unknown
make[1]: *** [run] Error 173
make[1]: Leaving directory `/home/ben/synchro/Projects/FortranSim/build'
make: *** [run] Error 2
Replacing class (*) with integer allows a run without error messages.
Can this be a compiler bug?
Ben
Yes, this is a compiler bug, but one that has already been fixed in our sources. I expect the fix to appear in Update 7, scheduled for August. The issue ID is DPD200151584.
