29653 Discussions
Different behaviour of Release executable from Debug executable
Ilie__Daniel
The output that I get using the debug executable is correct. However, when I use therelease executable I do not get the same output.
Has anyone come across such problems where the release build behaved differently from the debug build? Any ideas how to track this problem down?
Daniel.
TimP
You might be interested in reading other posts on this question. Then, if you still have questions, ask a more specific question. You leave all sorts of possibilities; which compiler did you use, did you check for un-initialized variables, what options did you use, do you have an example?
Ilie__Daniel
Thank you, Tim18
