29651 Discussions
Difficult to assign polymorphic objects
Andrew_Smith
Valued Contributor I
This example shows how to implement a collection of polymorphic objects with a method to add an object on the end.
The code to assign the new object is nested select type construct since we are not allowed to intrinsic assign polymorphic types in F2003. We also need code to explictly allocate the copy. What if we had many levels of inheritance? The code becomes stupidly hard to write and maintain.
I know that the restriction on polymorphic intrinsic assignment has been lifted in F2008. Is Intel considering implementing this F2008 feature soon?
I realise that if I made item a pointer instead of an allocatable then the code might become simpler (not much probably). But we would then no longer have the safety of allocatables in terms of memory recovery.
[fortran]module things
   implicit none
   type BaseType
      integer a
   end type
   type, extends(BaseType) :: ExtendedType
      integer b
   end type
   type Collection
      class(BaseType), allocatable :: item
   end type
contains
   subroutine addObject(aCollection, anObject)
      type(Collection), allocatable, intent(inout) :: aCollection(:)
      class(BaseType), intent(in) :: anObject
      type(Collection), allocatable :: tempCollection(:)
      integer i, n
      n = size(aCollection)
      allocate(tempCollection(n + 1))
      do i = 1, n
         !tempCollection(i) = aCollection(i) !Error8296
         select type(new => aCollection(i)%item)
         type is(BaseType)
            allocate(BaseType::tempCollection(i)%item)
            select type(temp => tempCollection(i)%item)
            type is(BaseType)
               temp = new
            end select
         type is(ExtendedType)
            allocate(ExtendedType::tempCollection(i)%item)
               temp = new
            end select
         end select
      end do
      n = n + 1
      !tempCollection(i+1)%item = anObject !Error8296
      select type(new => anObject)
      type is(BaseType)
         allocate(BaseType::tempCollection(n)%item)
         select type(temp => tempCollection(n)%item)
         type is(BaseType)
            temp = new
         end select
         allocate(ExtendedType::tempCollection(n)%item)
            temp = new
         end select
      end select
      deallocate(aCollection)
      call move_alloc(tempCollection, aCollection)
   end subroutine
end module
program AssignClass
   use things
   type(Collection), allocatable :: someObjects(:)
   type(BaseType) :: part
   type(ExtendedType) :: newPart
   allocate(someObjects(2))
   allocate(BaseType::someObjects(1)%item)
   allocate(ExtendedType::someObjects(2)%item)
   !Assign some values to help debug
   someObjects(1)%item%a = 1
   someObjects(2)%item%a = 2
   select type(p => someObjects(2)%item)
      p%b = 20
   end select
   part%a = 3
   newPart%a = 4
   newPart%b = 40
   call addObject(someObjects, part)
   call addObject(someObjects, newPart)
end program[/fortran]
joseph_battelle
Some of this gets easier even in F2003 when Intel supports (and fully debugs) allocate(..., source=poly) and move_alloc where poly is a regular or unlimited polymorphic source. Right now you have to do a lot of the select type and separate assignment gymnastics due to limitations in F2003 support. I don't think it's a big deal to have to create an assignment operator for polymorphic types but implementing the assignment operator or copy constructor with today's compiler is not as easy as it could be.
thomas_boehme
New Contributor II
I would also welcome a comment from Intel on this issue.
We are facing the same problem. The solution with the select type statements is cumbersome, as it has to be extended for each new derived type.
Thomas
Wendy_Doerner__Intel
With our 12.0 Compiler, the above code compiles and we have added Fortran 2008 support for
GENERIC, OPERATOR, and ASSIGNMENT overloading in type-bound procedures
We are unable to comment on future products, but take input on missing features to be implmented into account when prioritizing features for the next release.
Wendy
Attaching or including files in a post
