29657 Discussions
Difficulty in running simulation using LS-Dyna Version R14 and Intel(R) 64, Version 2021.8.0
AbhishekRaj
Dear All,
Request your support to run one element uniaxial test simulation using user subroutine in LS-Dyna. Currently we have LS-Dyna Version R14 and Intel(R) 64, Version 2021.8.0 are installed in our system.
It is showing message (lsdyna.exe - Entry Point not found  The procedure entry point__kmpc_aligned_alloc could not be located in the dynamic link library  C:\LSDYNA\program\lsdyna.exe
Thanks & Regards
Abhishek Raj
Arjen_Markus
This has little to do with the program you are trying to run but everything with the runtime DLLs it finds. This thread ma hold the solution to your problem: https://community.intel.com/t5/Intel-Fortran-Compiler/Procedure-entry-point-kmpc-aligned-alloc-could-not-be-located/m-p/1330222/highlight/true
