Distributed Coarray Fortran: misunderstanding/bug?
Jeremie_V_
Dear,
Below is a Coarray Fortran program that gives me some troubles:
A large vector (x) is updated in two different ways. For large sizes of x, the updates of x is wrong WHEN each image is on a different node. WHEN all images are on the same node, results are always fine, whatever the size of x.
When size(x)=10^6, exchanging the full array across images on different nodes led to wrong results. However, exchanging small subsets of x led to correct results.
When size(x)>2*10^7, exchanging the full array across images on different nodes led to wrong results, AND exchanging subsets of x  (size(subset) > 6*10^6) led to wrong results too.
My troubles seem to be linked to the size of the array that is exchanged across images on different nodes. So, am I doing something wrong? Could it be a bug?
I use ifort 17.0.0 with -coarray=distributed.
Here is the program that mimicks the problem (it may be stupid, with too many sync all, .... , but it is to replicate my issue):
program testcoarray
 implicit none
 integer(kind=4)::i,j,k,neq
 integer(kind=4)::startrow
  • ,endrow
  • real(kind=8)::val
  • real(kind=8),allocatable::x(:)[:] neq=1000000 neq=25806732 if(this_image().eq.1)then write(*,'(/a,i0)')' Size of the array: ',neq write(*,'(a,i0/)')' Number of images : ',num_images() endif !INITIALISATION i=neq/num_images() startrow=(this_image()-1)*i+1 endrow=this_image()*i if(this_image().eq.num_images())endrow=neq allocate(x(neq)
  • ) sync all !FIRST UPDATE x=0.d0 x(startrow:endrow)=real(this_image(),8) sync all if(this_image().eq.1)then do i=2,num_images() x=x+x(:) enddo write(*,*)' First update : ',sum(x) endif sync all !SECOND UPDATE x=0.d0 x(startrow:endrow)=real(this_image(),8) sync all if(this_image().eq.1)then do i=2,num_images() j=startrow k=endrow x(j:k)=x(j:k)+x(j:k) enddo write(*,*)' Second update: ',sum(x) endif sync all !CORRECT ANSWER x=0.d0 x(startrow:endrow)=real(this_image(),8) val=sum(x) sync all if(this_image().eq.1)then do i=2,num_images() val=val+val enddo write(*,*)' Correct value: ',val endif sync all end program
    And here are the output for neq=1000000
    *With all images on the same node:
     Size of the array: 1000000
     Number of images : 4
      First update :    2500000.00000000
      Second update:    2500000.00000000
      Correct value:    2500000.00000000
    *With each image on a different node:
      First update :    750000.000000000
    And here are the output for neq=25806732
     Size of the array: 25806732
      First update :    64516830.0000000
      Second update:    64516830.0000000
      Correct value:    64516830.0000000
      First update :    19355049.0000000
      Second update:    6451727.00000000
    In advance thank you for your help.
    Jeremie
    Michael_S_17
    I did test your program successfully with gfortran 8.0.1 (experimental version) and OpenCoarrays 2.0.0 on a shared memory laptop computer. The results are:
      First update :    2500000.0000000000
      Second update:    2500000.0000000000
      Correct value:    2500000.0000000000
    and
      First update :    64516830.000000000
      Second update:    64516830.000000000
      Correct value:    64516830.000000000
    From this, I would say your program seems to be correct. Could be a compiler bug. But I would also ask what values the this_image() and num_images() intrinsics do give with your program executing each image on different computing nodes?
    Jeremie_V_
    Thank you Michael S. for your tests.
    Regarding this_image() and num_images() on different compute nodes, both intrinsics give the expected values (i.e., num_images() returns 4 on all nodes, and this_images returns the ID of the image (from 1 to 4)). I tested it with success.
    I will install OpenCoarray and test my test program on our HPC, before reporting a potential bug...
    Michael_S_17
    If you want to install (actually, it is not necessarily required to install it) OpenCoarrays on a cluster you may be required to use a simple 'trick', as it is described here:
    https://groups.google.com/forum/#!topic/opencoarrays/sdUECeRNJo8
    In case you need help with the installation, feel free to ask at the OpenCoarrays forum: https://groups.google.com/forum/#!forum/opencoarrays/join
    cheers
    Jeremie_V_
    I installed OpenCoarrays using gcc 7.1.0 with the trick from your link (Thank you Michael S. for the trick!), compiled my program, and tested it on the HPC.
    I assigned one image per node, and got the correct result!
    So, it really seems to be a bug of the the Intel compiler 17.0.0!
    Thank you Michael S. for your help!
    Jeremie
