Distributed dll question
dondilworth
New Contributor II
My project has Fortran and C++, and the latter is the main program. When I create a setup.exe with Visual Studio, it works when I test it on the same PC. But if I install it on another PC, also running Windows 7, it fails to run with the error that libifcoremd.dll is missing. I tried adding the redistributable "Visual C++ 10.0 OpenMP (x86), but it did the same thing. What, exactly, to I have to add so that this error goes away?
We provide .msm merge modules and executable installers for the Intel compiler redistributables. See here for more info.
dondilworth
New Contributor II
Steve:
This is tantalizing, but a newbe needs more than a hint. I gather from the site you pointed at that I need to use the file
w_fcompxe_redist_ia32_2011.7.258.msm.
Now all I need is a hint saying exactly how to use it. Do I include it somewhere in the InstallShield stuff? Where, and how?
I am not an InstallShield user, but a .msm is something you add to a Windows Installer build. You'll have to study the InstallShield documentation for more on this. Microsoft provides a .msm for Visual C++ redistributables which you should also use.
