Do Concurrent
David_DiLaura
Colleagues:
The documenation for the DO CONCURRENT statement reports that it: "Specifies that there are no data dependencies between the iterations of a DO loop."
If /Qparallel is specified (or the appropriate optimization parameter is set in VS) does this mean that the loop is always parallelized? Does the statement surpress the compiler's examination for dependencies?  There must be some other criteria, since the DO CONCURRENT I've put in place of a conventional DO is not being parallelized. There are no dependensices, explicit or implicit.
How does the compiler treat DO CONCURRENT? Is there a place where the details are set down? -- the documentation doesn't provide them.
David
TimP
/Qopt-report would give a confirmation of whether you achieved parallel and vector compilation, You could add /Qguide in order to get suggestions. In case you don't care about efficiency of parallelization, /Qpar-threshold can be used to increase aggressiveness of parallelization. /Qparallel usually requires nested loops to parallelize without lowering the threshold. I haven't seen much usage of /Qparallel, as it is straightforward to use OpenMP parallel do in the case where you have made a loop eligible for DO CONCURRENT.
DO CONCURRENT does not guarantee parallelization. If you enable /Qparallel, the compiler will attempt to parallelize the construct body and the use of DO CONCURRENT gives the compiler additional information that enables it to parallelize and vectorize better. As Tim says, you can use the optimization report to see what got parallelized. Internal details are not available, but you can think of it as autoparallelization with directives specifying that there are no loop-carried dependencies.
