29640 Discussions
Do Intel Visual Fortran Compiled Binaries work for Windows Server 2012?
Nan_Deng
I have a program which was compiled on a Windows 7 OS machine and worked perfectly for Windows Server 2008 based servers.  Recently one of our servers upgraded to Windows Server 2012, and the compiled binaries do not run on that machine.  I am wondering if the code compiled under Windows 7 could be incompatible under Windows Server 2012 (or Windows 8.1).  Did Intel staff ever discover any problem for the new OS?  If I need a new re-compilation, which is the minimum new version I need to download to make it work?
We aren't aware of any issues and we test that OS. What exactly goes wrong? What is the exact and complete text of any error messages you receive?
FortranFan
No problems whatsoever in our experience for Fortran DLLs compiled with Intel Fortran compiled on Windows 7 and deployed on Windows Server 2012 (and 2008).
Nan_Deng
It just shows the message in a small blue box "XXXX.exe has stopped working". By clicking the "view details" button I got the following:
  Problem Event Name: APPCRASH
  Application Name: SITE.exe
  Application Version: 0.0.0.0
  Application Timestamp: 526592e9
  Fault Module Name: ntdll.dll
  Fault Module Version: 6.2.9200.16579
  Fault Module Timestamp: 51637f77
  Exception Code: c0000005
  Exception Offset: 0000000000059a85
  OS Version: 6.2.9200.2.0.0.272.7
  Locale ID: 1033
  Additional Information 1: e3a0
  Additional Information 2: e3a058d71e4f380cf7cda08dd6dc8dff
  Additional Information 3: b87e
  Additional Information 4: b87e04607c416c87ae09fe8f4edc5a2d
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=190175
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Does these lines make any sense?  Please help.
The only thing one can get from this is that there was an access violation, though I would have expected a Fortran error message and a traceback. On the other hand, the mention of ntdll.dll suggests a more fundamental problem. Does this happen immediately on running the program, or can you see that the program started? Can you build and run a "Hello World" program on this system (or build it elsewhere and run it here)?
Nan_Deng
It turns out the problem was caused by the encryption/key protection program which was binded to the binaries after Fortran compilation is done. I'll have to dig out new version of that software. Thank you for your help.
