29386 Discussions
Documentation clarification: BIT intrinsic
ereisch
New Contributor II
https://www.intel.com/content/www/us/en/develop/documentation/fortran-compiler-oneapi-dev-guide-and-reference/top/language-reference/a-to-z-reference/a-to-b/bit.html
The above documentation notes that the first parameter "Must be in the range 0 (least significant bit) to 31 (most significant bit)", but also notes that the second parameter can be an INTEGER(4) or an INTEGER(8).  Does the function support testing bits 32-63, or does it only support examining the first 32 bytes of a 64-bit operand?
A quick test of an example program shows that it does indeed correctly support examining the upper bits of 64-bit operands, so it appears the documentation is incorrect for the "bitnum" parameter.
It is also unclear as to what happens if you attempt to examine higher-order bits of 32-bit operands:
INTEGER*4   A
A = 32768
IF ( BIT(41, A) ) WRITE(*,*) 'TEST PASSED'
The above compiles and executes successfully (and no output is generated), but is it legal, and/or is it addressing beyond the scope of 'A'?
mecej4
The documentation on the related subroutines BIC/BIS seems clear enough:
USE IFPORT
CALL BIC
bitnum
target
CALL BIS
bitnum
target
bitnum (Input) INTEGER(4). Bit number to set.
     Must be in the range 0 (least significant bit) to 31 (most significant bit) if target is INTEGER(4).
     If target is INTEGER(8), bitnum must be in range 0 to 63
A more delicate question is whether the compiler is able to catch the error (bit number > 31 for a 4 byte target) in your example code when asked.
Would it not be safer to use similar functionality that is covered by the standard, such as BTEST, etc., instead of DEC/Compaq/Intel extensions?
JohnNichols
Valued Contributor III
 program Console31
    use IFPORT
    implicit none
    INTEGER*2   A,B
    Integer*4 pos
    pos = 41
    A = 32767
    B = A + 1
    if(B < 0) then
        write(*,*)" Wrong Integer type"
    else IF ( BTEST(41, A) .eq. 1) then
    else
        write(*,*) "Something bad happened"
    end if
    end program Console31
Should BTEST not test for the integer length?  Just a thought.
Steve_Lionel
It would be reasonable to do so, but I doubt it happens.
JohnNichols
No I checked it does not, so I added a simple test.  Of course to test for all integers the else if would get a lot longer.
Should it not be checked at compile time?  Is this not a bug?
Steve_Lionel
It's not a bug - such checking is not required. You could have a variable with the position and the compiler can't check. The function could check and raise some sort of error.
NAG Fortran does check at compile time:
NAG Fortran Compiler Release 7.1(Hanzomon) Build 7108
Error: t.f90, line 2: POS argument (41) to intrinsic BTEST out of range (0:31)
[NAG Fortran Compiler error termination, 1 error]
I'll note that the test case above gets the arguments in the wrong order.
mecej4
Apart from the other issues that have been discussed, please note that the line of code
is in error since BTEST is of type logical, and its returned value is being compared to the integer constant 1.
