29605 Discussions
Does Intel Fortran Compiler Runtime for Windows install IFORT compiler?
GuiRocARS
I need to install the classic Intel Fortran Compiler IFORT. I work with MS Visual Studio 2022.
First I downloaded and installed oneAPI Base Toolkit 2024.2, then downloaded and installed HPC toolkit 2025.1 but I realised it doesn't include ifort compiler, only ifx. So I downloaded and installed the Intel Fortran Compiler Runtime for Windows 2024.2.1/2021.13.0 but when I try to open a Fortran Project saved under Win32, Visual Studio says IFORT isn't installed.
For each installation, I went with default installation. Is there a specific way to install the runtime version so I can use ifort compiler? Or a parameter in Visual Studio?
Andrew_Smith
Valued Contributor I
The runtime installer does not install compilers. It's for your users to install so that your compiled program can run. The IFORT compiler is no longer available, unless you have a paid support contract.
Andrew_Smith
