29487 Discussions
Does the problem occur when gfortran and intel fortran are installed at the same cluster?
kim__seongik
Hello
Does the problem occurs when gfortran and intel fortran are installed at the same cluster (linux centos)???
Thank you for reading!!
Seongik Kim
Arjen_Markus
We have had that set-up for many years and I have never encountered a problem that could be related to both gofrtran and Intel Fortran being installed on the same system.
Do you have any reason to suspect it is a problem?
Arjen_Markus
kim__seongik
No
I just wondering about that situation.
Thank you for your reply
