29653 Discussions
Dwarf debug info missing for variable used in contained routine
Sagan__David
Consider the following test  program:
program test
implicit none
call bmad_parserx ()
end program
subroutine bmad_parserx ()
implicit none
integer zzz, kk
zzz = 2
call parser_end_stuff (.false.)
print *, zzz
contains
subroutine parser_end_stuff (do_dealloc)
logical, optional :: do_dealloc
integer i, j
zzz = 7
end subroutine parser_end_stuff
end subroutine bmad_parserx
Compiling with debug "ifort -g test.f90 and then looking at the dwarf debug info gives:
> readelf -w a.out |grep DW_AT_name
    <10>   DW_AT_name        : (indirect string, offset: 0x22): test.f90
    <35>   DW_AT_name        : (indirect string, offset: 0x9d): test
    <4f>   DW_AT_name        : (indirect string, offset: 0xa2): bmad_parserx
    <6a>   DW_AT_name        : kk
    <78>   DW_AT_name        : (indirect string, offset: 0xba): parser_end_stuff
    <97>   DW_AT_name        : (indirect string, offset: 0xd6): do_dealloc
    <a2>   DW_AT_name        : j
    <ae>   DW_AT_name        : i
    <bc>   DW_AT_name        : (indirect string, offset: 0xaf): INTEGER(4)
    <c3>   DW_AT_name        : (indirect string, offset: 0xcb): LOGICAL(4)
    DW_AT_name         DW_FORM_strp
    DW_AT_name         DW_FORM_string
The debug information for the variable "zzz" is missing which means that it is not possible to look at the value of zzz with a debugger. Is there any way around this? I am using ifort version 19.0.1.144 20181018.
Sagan__David
One year later and latest version of ifort 19.1.1.217 still has the bug. Anyone have any idea when this will be addressed?
Steve_Lionel
Have you reported this using the Online Service Center? Just posting here isn't a reliable way of bringing problems to Intel's attention.
Sagan__David
Yes it has been reported directly to Intel.
Steve_Lionel
Good - you can use that to ask for updates.
