I know that ENTRY is obsolete but in my case it is the fastest way to accommodate old code to my purpose.
I expected that I can share variables between all ENTRYs. But I find strange difference.
Example:
program test
integer :: i
i=10
WRITE(*,*) 'I=',i
call atest()
call a1(i)
call a2()
end program
subroutine atest()
INTEGER :: ic
return
entry a1(i)
ic=i
WRITE(*,*) 'entry 1'
WRITE(*,*) 'ic=',ic
return
entry a2()
WRITE(*,*) 'entry 2'
WRITE(*,*) 'ic=',ic
end subroutine
Default:
> ifort test.f -o test
> ./test
I= 10
entry 1
ic= 10
entry 2
ic= 0
Debug:
> ifort -g test.f -o test
> ./test
I= 10
entry 1
ic= 10
entry 2
ic= 10
So, by default my common variable 'ic' is invisible to other entries, but not in debug mode.
Which one is correct ? I expected that debug mode is more correct.
(ifort (IFORT) 19.1.0.166 20191121)
"ic" is not a "common variable - it is a local and is undefined when coming in through a2. You'll need to add the SAVE attribute to ic if you want this to work.
The debugger has limited information about variables and, especially in cases such as this, may get it wrong.
Thanks for explanation.
