29362 Discussions
EQUIVALENCE and PUBLIC access (bug?)
Thomas_F_1
The following code does not compile unless I remove the equivalence statement:
module one
implicit none
save
type mytype
  sequence
  integer :: i = 42
  integer :: j = 67
  integer :: k = 76
end type
! Instantiate sequence type
type (mytype) :: me
! Establish common block
integer :: i,j,k
common /xx/ i,j,k
! Eqv type with common
equivalence (me, i)
end module one
module two
! Restrict access through seq type only (not /xx/)
use one, only: me
implicit none
private
! Allow access through use association
public :: me
contains
subroutine sub
print *, "I = ",me%i
end subroutine
end module two
program test
use two
implicit none
end program
The compiler error is as follows:
test.f90(49): error #6404: This name does not have a type, and must have an explicit type.   [ME]
test.f90(49): error #6460: This is not a field name that is defined in the encompassing structure.
Note that it does not complain about the usage on line 39. I can't find anything in the texts that I have that would suggest this isn't allowed. Without the equivalence statement, everything compiles and runs just fine, and the "public" ME variable accessible through use association works as expected. Could this be a flaw in the compiler? Or am I missing something in the standard?
Thomas_F_1
I forgot to mention that if I remove the PRIVATE and PUBLIC statements, the code compiles fine, but then the entirety of module two is public, which is not what I want.
Thanks - I think this one is fixed but I need to check...
Yes, this is fixed for the 15.0 release later this year. The fix is not in the current beta.
Thomas_F_1
Good to hear. I look forward to the update.
