ERROR - Syntax error, found....
Noele_L_
I have this error and my code is just below, can someone help me?
read_co2atm.f90(1): error #5082: Syntax error, found '(' when expecting one of: <END-OF-STATEMENT> ;
       program read_co2atm(futr_scen, nco2rec, yrco2rec, atmco2rec)
read_co2atm.f90(21): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
       OPEN(luco2+1, FILE='splmlo_co2_noces.dat', FORM='formatted',
read_co2atm.f90(22): error #5082: Syntax error, found '&' when expecting one of: <LABEL> <END-OF-STATEMENT> ; TYPE INTEGER REAL COMPLEX BYTE CHARACTER CLASS DOUBLE ...
      &     STATUS='old')
read_co2atm.f90(22): error #5276: Unbalanced parentheses
      &     STATUS='old')
read_co2atm.f90(22): error #5082: Syntax error, found ')' when expecting one of: <END-OF-STATEMENT> ;
      &     STATUS='old')
read_co2atm.f90(33): error #5082: Syntax error, found '&' when expecting one of: <LABEL> <END-OF-STATEMENT> ; TYPE INTEGER REAL COMPLEX BYTE CHARACTER CLASS DOUBLE ...
      &      yrco2rec(irec),atmco2rec(irec)
read_co2atm.f90(39): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
       WRITE(*,*) 'Atm. CO2:  No. of entries for 1-box atmosphere =',
read_co2atm.f90(40): error #5082: Syntax error, found '&' when expecting one of: <LABEL> <END-OF-STATEMENT> ; TYPE INTEGER REAL COMPLEX BYTE CHARACTER CLASS DOUBLE ...
     &            nco2rec
compilation aborted for read_co2atm.f90 (code 1)
My code
       IMPLICIT NONE
       INTEGER maxrec, nmxr
       PARAMETER (maxrec=1200, nmxr=700)
       REAL yrco2rec(maxrec), atmco2rec(maxrec)
       INTEGER luco2, irec
       INTEGER nco2rec
       INTEGER is, ireadf
       INTEGER nsipl, nstab
       REAL futco2(nmxr,8)
       REAL dummy
       CHARACTER*4 futr_scen
       luco2=50
      &     STATUS='old')
       WRITE(*,*)'  '
       WRITE(*,*)'--------------------------------------------------'
       WRITE(*,*)'Atm. CO2 from fit to Siple-Mauna Loa record'
       DO irec=1,maxrec
        READ(luco2+1,*,ERR=222,END=222)
        nco2rec = irec
       END DO
 222   CONTINUE
     &            nco2rec
       CLOSE(luco2+1)
       RETURN
       END
mecej4
  1. The Program statement should not have an argument list.
  2. Most of your lines have seven leading blanks instead of the usual six.
  3. Continuation marks '&' should be in column-6, but you have them in column-7.
  4. The main program unit should not contain a RETURN statement
Noele_L_
Thanks mecej4
but now is showing this
 >$ifort read_co2atm.f90
 /opt/intel/opt/intel/compilers_and_libraries_2016.2.181/linux/compiler/lib/intel64_lin/for_main.o: In function `main':
 for_main.c:(.text+0x2a): undefined reference to `MAIN__'
mecej4
Sorry, I overlooked the name that you gave the file a suffix of ".f90", which is meant to be used for free-format Fortran source. Your file is fixed-format source, so you should call it "read_co2atm.f".
Please attach your updated code and state what name you gave to the source file.
When you attach source code, please do so using the {...} code button on the tool bar, and choose "Fortran".
Noele_L_
ERROR
read_co2atm.f(21): error #5082: Syntax error, found '&' when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
      OPEN(luco2+1, FILE='splmlo_co2_noces.dat', FORM='formatted', &
read_co2atm.f(23): error #5276: Unbalanced parentheses
           STATUS='old')
read_co2atm.f(23): error #5082: Syntax error, found ')' when expecting one of: <END-OF-STATEMENT> ;
           STATUS='old')
read_co2atm.f(33): error #5082: Syntax error, found '&' when expecting one of: , <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
      READ(luco2+1,*,ERR=222,END=222) &
read_co2atm.f(34): error #5082: Syntax error, found ',' when expecting one of: => = . [ % (
read_co2atm.f(40): error #5082: Syntax error, found '&' when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
      WRITE(*,*) 'Atm. CO2:  No. of entries for 1-box atmosphere =', &
read_co2atm.f(41): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
                nco2rec
compilation aborted for read_co2atm.f (code 1)
CODE
      SUBROUTINE read_co2atm(futr_scen, nco2rec, yrco2rec, atmco2rec)
      IMPLICIT NONE
      INTEGER luco2, irec
      INTEGER nco2rec
      INTEGER is, ireadf
      REAL futco2(nmxr,8)
      REAL dummy
      luco2=50
           STATUS='old')
      WRITE(*,*)'  '
      DO irec=1,maxrec
       nco2rec = irec
      END DO
222   CONTINUE
                nco2rec
      CLOSE(luco2+1)
      END
mecej4
Well, you converted the program to a subroutine.
You used incorrect notation for indicating continuation lines. An '&' character at the end of a line is used to indicate continuation in free-format. In fixed-format, you place one of the acceptable continuation characters in column-6. Please read your Fortran textbook/manual to get these requirements right.
A subroutine cannot be run by itself. It has to be called by another subprogram or main program. Every program must contain one and only one main program unit and, if needed, any number of subroutine and function subprograms.
Noele_L_
Dear mecej4
I was confused and sent the wrong codes...
PROGRAM try_read_co2atm
C     ------------------------------------------------------------------
C     Test PROGRAM to READ historical atmospheric CO2 (uatm)
C
      IMPLICIT NONE
      INTEGER luco2, irec
      INTEGER nco2rec
      INTEGER is, ireadf
      REAL futco2(nmxr,8)
      REAL dummy
      CALL read_co2atm('test', nco2rec, yrco2rec, atmco2rec)
      DO irec=1,nco2rec
        WRITE(*,'(2f8.2)') yrco2rec(irec),atmco2rec(irec)
      END DO
      STOP
      END
      IMPLICIT NONE
      INTEGER luco2, irec
      INTEGER nco2rec
      INTEGER is, ireadf
      REAL futco2(nmxr,8)
      REAL dummy
C     OPEN FILE
C     ---------
      luco2=50
     &     STATUS='old')
C     Get atmospheric CO2 data
      WRITE(*,*)'  '
C     READ historical co2 concentrations
C     READ(luco2+1,200)
C 200  FORMAT(////)
      DO irec=1,maxrec
C           Read from splco2.dat (historical emissions)
        nco2rec = irec
      END DO
 222  CONTINUE
     &            nco2rec
      CLOSE(luco2+1)
      RETURN
      END
mecej4
The program comprising the two files that you displayed in #7 compile and link fine. However, I cannot run the program since I do not have the data file that it needs to read.
Is your problem solved at this point?
Noele_L_
Not yet..
Now I have this
$ ifort try_read_co2atm.f
/tmp/iforteO9RD2.o: In function `MAIN__':
try_read_co2atm.f:(.text+0x51): undefined reference to `read_co2atm_'
mecej4
You need to specify all the sources needed. If your subroutine is in a file that you named read_co2atm.f, the command to compile and link would be
     $ ifort try_read_co2atm.f read_co2atm.f
If you had more subroutines/functions in more source files, and those routines are needed to run your program, you should have listed all of them, as well.
Noele_L_
Thank you very much
I had a little thought about my knowlodge in Fortran
Clearly I was wrong
Thanks again..
muzammil__muhammad
I am unable to get my results from this code and I cant understand what are the errors can someone correct my code?
thankyou
! program to trace the path of a charged particle under certain magnetic field
      program tracer
      implicit none
      real*8 etahe,etaox,alphastar,KE,omega,t,k,Bx
      !initial values
      ke=ke*2*10**6*e
      omega=0.001
      t=0
      k=0.21
      etahe = 0.2
      etaox=0
      alpstar=0.01
      x=0.24
!dispersion relation to obtain wave vector(number) k
      eps1=(1/alphastar*eps)*[(1-etahe-etaox)/(1-x**2)+4*etahe/(1-4**2*
     &x**2)+16*etaox/(1-16**2*x**2)]
      eps2=(1/alphastar*eps*x)*[1-(1-etahe-etaox)/(1-x**2)+etahe/
     &(1-4**2*x**2)-etaox/(1-16**2*x**2)]
      eps3=-(1/alphastar*eps**2*x**2)
      n**2=1/2*(cos(theta))**2*(eps1*(1+(cos(theta))**2))+sqrt(eps1**2*
     &(1-(cos(theta))**2)+4*eps2**2*(cos(tehta)**2))
! Normalization of equations
!choice of normalization
      KE=KE/mc**2
      ω=ω/Ωeo
      t=tΩeo
      k=kc/Ωeo
      Bx=Bx/Bzo
      E=E/cBzo
      p=p/mc
      x=x/(c/Ωeo)
      y=y/(c/Ωeo)
      z=z/(c/Ωeo)
      pꞌ⊥o=sqrt(KE**2+2KE)
      pꞌzo=sqrt(KE**2+2KE)
      γ=KE+1
!polarization equations in normalized form
      Bꞌwx=(kꞌ/ωꞌ)*cos(ψ)*Eꞌwy
      Eꞌwy=(1/cos(ψ))*[(ωꞌ/kꞌ)*Bꞌwx]
      Bꞌwz=(kꞌ/ωꞌ)*sin(ψ)*Eꞌwy
      Eꞌwx=Eꞌwy*(ϵ1-(kꞌ/ωꞌ)**2)/ϵ2
      Eꞌwz=Eꞌwx*((kꞌ/ωꞌ)**2)*cos(ψ)*sin(ψ))/(ϵ3-(kꞌ/ωꞌ)**2)*sin**2(ψ) ! < 0 for ψ<π/2
      Bꞌwy=(kꞌ/ωꞌ)*cos(ψ)*Eꞌwx+(kꞌ/ωꞌ)*sin(ψ)*Eꞌwzwe
      ω1=(-Ωe/2)*(Bꞌwx+Bꞌwy)
      ω2=(-Ωe/2)*(Bꞌwx-Bꞌwy)
      a1=(-e*Bzo*c/2)*(Eꞌwx+Eꞌwy)
      a2=(-e*Bzo*c/2)(Eꞌwx-Eꞌwy)
!using the normalization parameters
      dpꞌ/dtꞌ=-(Eꞌw+(pꞌ×Bꞌw)/γ)-(1/γ)*(pꞌ×Bꞌo)
!Normalization of equation
      dpꞌz/dtꞌ=-Eꞌwz*sin(Φ)+(1/2*γ)*(Bꞌwx*pꞌ⊥)[(1+ϵ)*sin(η)+(1-ϵ)
     &*sin(η-2Φ)]-(pꞌ⊥/2*γ)*(dBꞌoz/dzꞌ)*[xꞌ*sin(η-Φ)-yꞌ*cos(η-Φ)]
!normalization
      dpꞌ⊥/dtꞌ={-pꞌz*Bꞌwx*(1+ϵ)*(1/2*γ)+[Bꞌwx*ωꞌ*(ϵ+1)*(1/2*kꞌ*cos(ψ))
     &-Eꞌwz*tan(ψ)(1/2)]}*sin(η)+{-pꞌz*Bꞌwx*(1-ϵ)*(1/2*γ)+[-Bꞌwx*ωꞌ
     & *(ϵ-1)*(1/2*kꞌ*cos(ψ))+Eꞌwz*tan(ψ)(1/2)]}*sin(η-2Φ)}+(pꞌz/2*γ)
     &*[xꞌ*sin(η-Φ)-yꞌ*cos(η-Φ)]*(dBꞌoz/dzꞌ)
!Normalization
      dꞌθ/dtꞌ=(Ωe/Ωeo*γ)-(Ωe/Ωeo*dpꞌ⊥){-pꞌz*Bꞌwx*(1+ϵ)*(1/2γ)+[Bꞌwx*ωꞌ
     &*(ϵ+1)*(1/2*kꞌ*cos(ψ))-Eꞌwz*tan(ψ)*(1/2)]}*sin(η)+{-pꞌz*Bꞌwx*
     &(1-ϵ)*(1/2*γ)+[-Bꞌwx*ωꞌ*(ϵ-1)*(1/2*kꞌ*cos(ψ))-Eꞌwz*tan(ψ)*(1/2)]}
     &*sin(η-2Φ)-(Ωe*Bꞌwz/γ)*(cos(Φ))-(Ωe*pꞌz/γ)*(pꞌ⊥*Bꞌo⊥/pꞌ⊥**2)
!normalization
      dphi/dt=Φꞌ=ωꞌ-(kꞌ*pꞌz/γ)*cos(ψ)-(kꞌ*pꞌz/γ)*cos(η-Φ)*sin(ψ)
!normalization
      (dη/dtꞌ)=(dθ/dtꞌ)+ωꞌ-kꞌz(dxꞌ/dtꞌ)-kꞌx(dxꞌ/dtꞌ)
!normalization
      dz/dt=pz/γ*m
      dꞌz/dtꞌ=pꞌz/γ
!normalization
      dxꞌ/dtꞌ=(1/γ)*pxꞌ*cos(η-Φ)
!normalization
      dyꞌ/dtꞌ=(1/γ)*pꞌ⊥*sin(η-Φ)
      !evolution of pitch angle
      cos(alpha)=pz/sqrt(pz**2+p⊥**2)
!runge-kutta subroutine
!    Classical 4th-order Runge-Kutta method(OK)
    SUBROUTINE rk4(y,x,h,derivs)
    include "data.inc"
    REAL*8 h,x,dydx(ndim,nv),y(ndim,nv)
    EXTERNAL derivs
! Given values for the variables y(1:n) and their derivatives dydx(1:n) known at x, use
! the fourth-order Runge-Kutta method to advance the solution over an interval h and return
! the incremented variables as yout(1:n), which need not be a distinct array from y. The
! user supplies the subroutine derivs(x,y,dydx), which returns derivatives dydx at x.
    INTEGER i,j
    REAL*8 h6,hh,xh,dym(ndim,nv),dyt(ndim,nv),yt(ndim,nv)
    hh=h*0.5
    h6=h/6.
    xh=x+hh
    call derivs(x,y,dydx)  ! First step
    do 10 j=1,nv
    do 10 i=1,ndim
        yt(i,j)=y(i,j)+hh*dydx(i,j)
10    continue
    call derivs(xh,yt,dyt) ! Second step
    do 11 j=1,nv
    do 11 i=1,ndim
        yt(i,j)=y(i,j)+hh*dyt(i,j)
11    continue
    call derivs(xh,yt,dym) ! Third step
    do 12 j=1,nv
    do 12 i=1,ndim
        yt(i,j)=y(i,j)+h*dym(i,j)
        dym(i,j)=dyt(i,j)+dym(i,j)
12    continue
    call derivs(x+h,yt,dyt) ! Fourth step
    do 13 j=1,nv            ! Accumulate increments with proper weights
    do 13 i=1,ndim
        y(i,j)=y(i,j)+h6*(dydx(i,j)+dyt(i,j)+2.*dym(i,j))
13    continue
    return
    END
      ! before obtianing re-genaralize the equations
      KE=KE*mc**2
      ω=ω*Ωeo
      t=t/Ωeo
      k=k*Ωeo/c
      Bx=Bx*Bzo
      E=E*cBzo
      p=p*mc
      x=x*(c/Ωeo)
      y=y*(c/Ωeo)
      z=z*(c/Ωeo)
!results
      open(1,file='my_code_output.txt',status='new')
      read(1,*)x
      write(*,*)x
      read(1,*)y
      write(*,*)y
      read(1,*)z
      write(*,*)z
      read(1,*)location
      write(*,*)location
      read(1,*)p⊥
      write(*,*)p⊥
      read(1,*)pz
      write(*,*)pz
      pitch angle
      x, y, z location
       pㅗ
       p//
mecej4
Large parts of your "code" are not Fortran at all. Simply listing equations will not result in their getting solved. You have a subroutine, RK4, which presumably integrates ODEs. However, that subroutine is never called from any of the lines that you showed.
Please take a course in Fortran and numerical methods, or learn the required material by reading textbooks and online tutorials.
Let's look at the last part of your "code". You open a file with STATUS='NEW'; this action, if it succeeds, will create a new file with no contents. You then attempt to read from that file, but there is nothing in the file to read!
Mathematical symbols such as ㅗ cannot be used in variable names.
jimdempseyatthecove
' cannot be use as symbol constituent. 'this is text' "in addition to this"
Jim Dempsey
JohnNichols
Honored Contributor I
There are very many sample of ODE solvers on the web with many manuals.
If you are able to do the math for program to trace the path of a charged particle under certain magnetic field - then learning Fortran is simple and really you should have learnt to program before you got to a physics course that set a problem such as  -- program to trace the path of a charged particle under certain magnetic field
Usually in the academic world you are expected to do your own work --
