29650 Discussions
Edit source while running in Debug mode
Tony_the_D
I am running VS 2013 V 12.0.21005.1 and 2015 Composer Fortran for Windows (Package 2015.0.108).  I just installed in on a new computer and moved a solution and related projects and source from an existing older computer.  On the old computer, I am able to Edit source code while running a program.  I usually continue editing (while running in debug) until the line numbers get "lost", then I restart the program and continue.  On the new computer, all files are locked as soon as I start running in debug mode and I cannot edit even at a break point or by using break all.  I have checked file access settings etc and also the Edit and Continue settings and related debug settings and all appear similar between the two computers.
So any ideas on how to enable me to edit source code while running in debug mode?
andrew_4619
tools > options > debug > Edit and Continue > Enable edit and Continue
The option above be unticked might be the problem.
There was also a version that enforced this behaviour as an 'improvment' but it was dropped. See https://software.intel.com/en-us/forums/topic/550985
Tony_the_D
Thanks, but I have tried that option to no avail.  (Not sure how it would give different behaviour on two computers each running the same version of VS and Fortran Composer?)
Tony_the_D
The comment "a version that enforced this behaviour as an 'improvement' but it was dropped" was key.  I installed the latest version of Composer (2015.4.221) and that appears to have solved the problem (with the Edit and Continue box checked).  Thanks for the help.
