29487 Discussions
Efficieny of select case with multiple item case
Andrew_Smith
Valued Contributor I
I have a select case with maybe 400 cases. I have coded it into groups because I wanted to group selections belonging to function. Here is a simplification:
[bash]select case(i)
case (0:99)
   call selectFirst100(i)
case(100:199)
   call select100To200(i)
case((200:299)
   call select200To300(i)
case((300:399)
   call select300To300(i)
end select
subroutine selectFirst100(i)
   integer, intent(in) :: i
   select case(i)
   case(1)
       !Do something
   case(2)
       !ETC
   end select
end subroutine[/bash]
When I step through this in the VS debugger I notice that the top level select jumps around checking each case in turn until it finds one that matches, but the lower level one with single items in the cases jumps straight to the selection. It seams like a completly different approach it taken for the two cases and I was wondering if the multi-item (top level) selection has a penalty in speed?
Maybe I should do the top level differently like:
[bash]if (i > -1 .and. i < 100) then
else if (i < 200) then
else if (i < 300) then
else if (i < 400) then
   call select300To400(i)
end if[/bash]
The compiler does optimize simpler SELECT CASE constructs, but when there is a range, it reverts to a series of comparisons just like your replacement code. I suggest leaving the outer one as it is. Or you might do something like having the outer one select on i/100 with values of 0, 1, 2, etc. That would probably get optimized.
