Elemental Subroutine Vs. Looping
ScottBoyce
For my code I was wondering if there is a benefit to having a subroutine with an explicit loop across a vector compared to making an elemental subroutine.
What I really have are complex Derived Data Types that are dimensioned and I can either loop through them with a subroutine or pass them as an elemental subroutine. The only real code difference is having an extra loop and allocating space for the index of the loop.
This is a basic example of what I am talking about (There maybe some bugs cause i just quickly wrote this in the window...but its more to illustrate the difference that I am talking about).
MODULE TYPDEF
  TYPE MYTYP
              INTEGER, DIMENSION(5):: X,Y,Z
  END TYPE
  CONTAINS
  PURE ELEMENTAL ELEMENTAL_SUB(TYP)
     TYPE(MYTYP), INTENT(INOUT):: TYP
     TYP%Z = TYP%X + TYP%Y
  END SUBROUTINE
  PURE REGULAR_SUB(TYP)
     TYPE(MYTYP), DIMENSION(:), CONTIGUOUS, INTENT(INOUT):: TYP
     INTEGER:: I
     DO CONCURRENT (I=1:SIZE(TYP))
                                   TYP(I)%Z = TYP(I)%X + TYP(I)%Y
     END DO
  END SUBROUTINE
END MODULE
PROGRAM MAIN
USE TYPDEF
TYPE(MYTYP), DIMENSION(10):: TYP
  INTEGER:: I, J
  !JUST SOME RANDOM INITIALIZTING
  DO I=1,10
      DO J=1,5
              TYP(I)%X(J) = I + J
              TYP(I)%X(J) = I * J - J + I
      END DO
  END DO
  CALL ELEMENTAL_SUB(TYP)  !IS ELEMENTAL BETTER/FASTER?
  CALL REGULAR_SUB(  TYP)  !OR SHOULD IT USE EXPLICIT LOOPS
END PROGRAM
Which would be better, to process the derived data type?
Scott
IanH
If it is execution performance you are concerned with, then you would probably have to measure for your specific use case.  Ultimately, if the compiler is being reasonable, I wouldn't expect much of a difference.
From the point of view of the source code, I consider the elemental case to be more succinct.
Beyond that, the elemental form has broader application - it can also be applied to a scalar, or a non-contiguous array without potential performance implications.
Arjen_Markus
It is extremely difficult to give generally valid advice on this matter. (Note that you forgot the keyword SUBROUTINE in your code ;)).
Normally I would say that the first concern is whether your code is simpler - more readable, with elemental routines or not. Since you put the do-loop inside the routine, using either does not really matter. This would matter in the case of elemental functions - you would otherwise have to put the do-loop in the calling subprogram.
A second advantage of elemental routines is that you do not have to worry about providing multiple versions for scalar variables or one-dimensional, two-dimensional etc. arrays. That is still valid in your case. A variable (not an array) of type MY_TYPE could still be passed to ELEMENTAL_SUB, but for REGULAR_SUB you would need a different version.
Now the question about performance: the only advice I could give is, measure it. If it does not make a noticeable and significant difference, then use elemental routines. Elemental routines might be slower (according to common wisdom, no idea how accurate that was or still is), but if you substantial work - in this case you are using them for operations on array components, I doubt you will be able to measure a difference.
jimdempseyatthecove
You might want to consider using:
DO CONCURRENT (I=LBOUND(TYP):UBOUND(TYP))
Arrays are not necessarily 1 based. Or you could call your subroutine using a slice
CALL ELEMENTAL_SUB(TYP(Ifrom:Ito))
Jim Dempsey
Arjen_Markus
LBOUND and UNBOUND are not passed on automatically to routines for this reason.
