Equivalence
Luis_Thiago_L_
I`m trying replace the equivalence in my code. Example:
    SUBROUTINE SPA88 (        &
    & EXCTS   , CTSO3   , GXCTS   , SORC    , CSOUR   , CLDFAC  , TEMP    , PRESS   , VAR1         ,   &
    & VAR2     , P            , DELP      , DELP2   , TOTVO2  , TO3SP   , TO3SPC  , CO2SP1  , CO2SP2   ,   &
    & CO2SP)
    USE PARMETA
    USE HCON
    USE PHYCON
    USE RNDDTA
    INCLUDE "MPP.h"
#include "sp.h"
    PARAMETER (L=LM)
    PARAMETER (IMAX=IM              , NCOL=IMAX)
    PARAMETER (NBLX=47)
    PARAMETER (NBLM=NBLY-1)
    PARAMETER (LP1=L+1               , LP2=L+2        , LP3=L+3)
    PARAMETER (LM1=L-1                , LM2=L-2        , LM3=L-3)
    PARAMETER (LL=2*L                   , LLP1=LL+1     , LLP2=LL+2, LLP3=LL+3)
    PARAMETER (LLM1=LL-1             , LLM2=LL-2     , LLM3=LL-3)
    PARAMETER (LP1M=LP1*LP1      , LP1M1=LP1M-1)
    PARAMETER (LP1V=LP1*(1+2*L/2))
    PARAMETER (LP121=LP1*NBLY)
    PARAMETER (LL3P=3*L+2)
    PARAMETER (NB=12)
    PARAMETER (INLTE=3                 ,INLTEP=INLTE+1  , NNLTE=56)
    PARAMETER (LP1I=IMAX*LP1      ,LLP1I=IMAX*LLP1, LL3PI=IMAX*LL3P)
    PARAMETER (NB1=NB-1)
    PARAMETER (KO2=12)
    PARAMETER (KO21=KO2+1         ,KO2M=KO2-1)
    DIMENSION SORC  (IDIM1:IDIM2, LP1 , NBLY), CSOUR (IDIM1:IDIM2, LP1)
    DIMENSION CLDFAC(IDIM1:IDIM2, LP1 , LP1)
    DIMENSION TEMP(IDIM1:IDIM2, LP1)       , PRESS (IDIM1:IDIM2, LP1)
    DIMENSION  VAR1(IDIM1:IDIM2, L)           ,   VAR2  (IDIM1:IDIM2, L)
    DIMENSION       P(IDIM1:IDIM2, LP1)        ,   DELP  (IDIM1:IDIM2, L)  ,  DELP2 (IDIM1:IDIM2, L)
    DIMENSION TOTVO2(IDIM1:IDIM2, LP1)       , TO3SPC(IDIM1:IDIM2, L)  ,  TO3SP (IDIM1:IDIM2, LP1)
    DIMENSION CO2SP1(IDIM1:IDIM2, LP1)       , CO2SP2(IDIM1:IDIM2, LP1),  CO2SP (IDIM1:IDIM2, LP1)
    DIMENSION EXCTS (IDIM1:IDIM2, L)         , CTSO3 (IDIM1:IDIM2, L)  , GXCTS (IDIM1:IDIM2)
    DIMENSION PHITMP(IDIM1:IDIM2, L)         , PSITMP(IDIM1:IDIM2, L)  ,              &
    &         TT    (IDIM1:IDIM2, L)         ,        &
    &         FAC1  (IDIM1:IDIM2, L)         , FAC2  (IDIM1:IDIM2, L)  ,                           &
    &         CTMP  (IDIM1:IDIM2, LP1)       , X     (IDIM1:IDIM2, L)  ,                          &
    &         Y     (IDIM1:IDIM2, L)         ,                                                    &
    &         TOPM  (IDIM1:IDIM2, L)         , TOPPHI(IDIM1:IDIM2, L)  ,                          &
    &         CTMP3 (IDIM1:IDIM2, LP1)       , CTMP2 (IDIM1:IDIM2, LP1)
    DIMENSION F     (IDIM1:IDIM2, L)         , FF    (IDIM1:IDIM2, L)  ,                          &
    &         AG    (IDIM1:IDIM2, L)         , AGG   (IDIM1:IDIM2, L)
!    EQUIVALENCE (F , AG , PHITMP)
!    EQUIVALENCE (FF, AGG, PSITMP)
! EQUIVALENCE REPLACE
    DO I=1,L
        AG(IDIM1:IDIM2,I) = TRANSFER( F(IDIM1:IDIM2,L),    AG(IDIM1:IDIM2,I))
    END DO
    DO I=1,L
    PHITMP(IDIM1:IDIM2,I) = TRANSFER( F(IDIM1:IDIM2,L),PHITMP(IDIM1:IDIM2,I))
    END DO
    DO I=1,L
       AGG(IDIM1:IDIM2,I) = TRANSFER(FF(IDIM1:IDIM2,L),   AGG(IDIM1:IDIM2,I))
    END DO
    DO I=1,L
    PSITMP(IDIM1:IDIM2,I) = TRANSFER(FF(IDIM1:IDIM2,L),PSITMP(IDIM1:IDIM2,I))
    END DO
! COMPUTE TEMPERATURE QUANTITIES FOR USE IN PROGRAM
    DO 101 K=1,L
        DO 101 I=MYIS,MYIE
            X(I,K) = TEMP(I,K) - H25E2
            Y(I,K) =    X(I,K) * X(I,K)
    101 END DO
! INITIALIZE CTMP(I,1),CTMP2(I,1),CTMP3(I,1) TO UNITY; THESE ARE
! TRANSMISSION FCTNS AT THE TOP.
    DO 345 I=MYIS,MYIE
        CTMP (I,1) = ONE
        CTMP2(I,1) = 1.
        CTMP3(I,1) = 1.
    345 END DO
!***BEGIN LOOP ON FREQUENCY BANDS (1)***
! CALCULATION FOR BAND 1 (COMBINED BAND 1)
! OBTAIN TEMPERATURE CORRECTION (CAPPHI,CAPPSI),THEN MULTIPLY BY OPTICAL PATH (VAR1,VAR2) TO
! COMPUTE TEMPERATURE-CORRECTED OPTICAL PATH AND MEAN PRESSURE FOR A LAYER (PHITMP,PSITMP)
    DO 301 K=1,L
        DO 301 I=MYIS,MYIE
                  F(I,K) =  H44194M2  * (APCM   (1)    * X  (I,K)  + BPCM(1)  * Y(I,K))
                 FF(I,K) =  H44194M2  * (ATPCM  (1)    * X  (I,K)  + BTPCM(1) * Y(I,K))
                 AG(I,K) = (H1P41819  + F       (I,K)) * F  (I,K)  + ONE
                AGG(I,K) = (H1P41819  + FF      (I,K)) * FF (I,K)  + ONE
             PHITMP(I,K) =  VAR1(I,K) * (((( AG (I,K)  * AG (I,K))  ** 2) ** 2) **2)
             PSITMP(I,K) =  VAR2(I,K) * (((( AGG(I,K)  * AGG(I,K))  ** 2) ** 2) **2)
    301 END DO
! OBTAIN OPTICAL PATH,MEAN PRESSURE FROM THE TOP TO THE PRESSURE
! P(K) (TOPM,TOPPHI)
    DO 315 I=MYIS,MYIE
          TOPM(I,1) = PHITMP(I,1)
        TOPPHI(I,1) = PSITMP(I,1)
    315 END DO
    DO 319 K=2,L
        DO 317 I=MYIS,MYIE
              TOPM(I,K) =   TOPM(I,K-1) + PHITMP(I,K)
            TOPPHI(I,K) = TOPPHI(I,K-1) + PSITMP(I,K)
        317 END DO
    319 END DO
! TT IS THE CLOUD-FREE CTS TRANSMISSION FUNCTION
    DO 321 K=1,L
        DO 321 I=MYIS,MYIE
            FAC1(I,K)   = ACOMB(1)    *   TOPM(I,K)
            FAC2(I,K)   = FAC1 (I,K)  *   TOPM(I,K) / (BCOMB(1) * TOPPHI(I,K))
              TT(I,K)   = EXP  (HM1EZ *   FAC1(I,K) / SQRT  (1. + FAC2  (I,K)))
            CTMP(I,K+1) = TT   (I,K)  * CLDFAC(I,K+1,1)
    321 END DO
! EXCTS IS THE CTS COOLING RATE ACCUMULATED OVER FREQUENCY BANDS
    DO 353 K=1,L
        DO 353 I=MYIS,MYIE
            EXCTS(I,K) = SORC(I,K,1) * (CTMP(I,K+1) - CTMP(I,K))
    353 END DO
! GXCTS IS THE EXACT CTS TOP FLUX ACCUMULATED OVER FREQUENCY BANDS
    DO 361 I=MYIS,MYIE
        GXCTS(I) =  CLDFAC(I,LP1,1) * ( TT(I,L)      *  SORC(I,L,1)                               &
    &            + (HAF             * DELP(I,L)      * (  TT(I,LM1)    * (   P(I,LP1)             &
    &            - PRESS  (I,L))    + TT  (I,L)      * (   P(I,LP1)    + PRESS(I,L)               &
    &            - TWO              * P   (I,L))))   * (SORC(I,LP1,1)  -  SORC(I,L,1)))
    361 END DO
! CALCULATION FOR BAND 2 (COMBINED BAND 2)
    DO 401 K=1,L
        DO 401 I=MYIS,MYIE
                 F(I,K) =  H44194M2  * (   APCM(2)    *   X(I,K)  + BPCM (2) * Y(I,K))
                FF(I,K) =  H44194M2  * (  ATPCM(2)    *   X(I,K)  + BTPCM(2) * Y(I,K))
                AG(I,K) = (H1P41819  +        F(I,K)) *   F(I,K)  + ONE
               AGG(I,K) = (H1P41819  +       FF(I,K)) *  FF(I,K)  + ONE
            PHITMP(I,K) =  VAR1(I,K) * ((((  AG(I,K)  *  AG(I,K)) ** 2) ** 2) ** 2)
            PSITMP(I,K) =  VAR2(I,K) * (((( AGG(I,K)  * AGG(I,k)) ** 2) ** 2) ** 2)
    401 END DO
    DO 415 I=MYIS,MYIE
        TOPM  (I,1) = PHITMP(I,1)
    415 END DO
    DO 419 K=2,L
        DO 417 I=MYIS,MYIE
        417 END DO
    419 END DO
    DO 421 K=1,L
        DO 421 I=MYIS,MYIE
            FAC1(I,K)   = ACOMB(2)    *   TOPM(I,K)
            FAC2(I,K)   =  FAC1(I,K)  *   TOPM(I,K) / (BCOMB(2) * TOPPHI(I,K))
              TT(I,K)   =   EXP(HM1EZ *   FAC1(I,K) / SQRT  (1. + FAC2  (I,K)))
            CTMP(I,K+1) =    TT(I,K)  * CLDFAC(I,K+1,1)
    421 END DO
    DO 453 K=1,L
        DO 453 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K)   + SORC(I,K,2) * (CTMP(I,K+1) - CTMP(I,K))
    453 END DO
    DO 461 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)         + CLDFAC(I,LP1,1) * (  TT(I,L)      *  SORC(I,L,2)            &
    &            - PRESS(I,L))      +     TT(I,L)     * (   P(I,LP1)    + PRESS(I,L)              &
    &            - TWO              *      P(I,L))))  * (SORC(I,LP1, 2) -  SORC(I,L,2)))
    461 END DO
! CALCULATION FOR BAND 3 (COMBINED BAND 3)
    DO 501 K=1,L
        DO 501 I=MYIS,MYIE
                 F(I,K) =  H44194M2  * (   APCM(3)    *   X(I,K)  + BPCM (3)   * Y(I,K))
                FF(I,K) =  H44194M2  * (  ATPCM(3)    *   X(I,K)  + BTPCM(3)   * Y(I,K))
            PSITMP(I,K) =  VAR2(I,K) * (((( AGG(I,K)  * AGG(I,K)) ** 2) ** 2) ** 2)
    501 END DO
    DO 515 I=MYIS,MYIE
    515 END DO
    DO 519 K=2,L
        DO 517 I=MYIS,MYIE
        517 END DO
    519 END DO
    DO 521 K=1,L
        DO 521 I=MYIS,MYIE
            FAC1(I,K)   = ACOMB(3)    *   TOPM(I,K)
            FAC2(I,K)   =  FAC1(I,K)  *   TOPM(I,K)      / (BCOMB(3) * TOPPHI(I,K))
              TT(I,K)   =   EXP(HM1EZ *   FAC1(I,K)      / SQRT  (1. +   FAC2(I,K)))
    521 END DO
    DO 553 K=1,L
        DO 553 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,3) * (CTMP(I,K+1) - CTMP(I,K))
    553 END DO
    DO 561 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)       + CLDFAC(I,LP1, 1) *  (TT(I,L)   *  SORC(I,L,3)                 &
    &            - PRESS(I,L))   +      TT(I,L)      * (  P(I,LP1) + PRESS(I,L)    - TWO          &
    &            *     P(I,L)))) * (  SORC(I,LP1,3)  - SORC(I,L,3)))
    561 END DO
! CALCULATION FOR BAND 4 (COMBINED BAND 4)
    DO 601 K=1,L
        DO 601 I=MYIS,MYIE
                 F(I,K) =  H44194M2   * (  APCM(4)     *   X(I,K)  + BPCM (4)    * Y(I,K))
                FF(I,K) =  H44194M2   * ( ATPCM(4)     *   X(I,K)  + BTPCM(4)    * Y(I,K))
    601 END DO
    DO 615 I=MYIS,MYIE
    615 END DO
    DO 619 K=2,L
        DO 617 I=MYIS,MYIE
        617 END DO
    619 END DO
    DO 621 K=1,L
        DO 621 I=MYIS,MYIE
            FAC1(I,K)   = ACOMB(4)    *   TOPM(I,K)
            FAC2(I,K)   =  FAC1(I,K)  *   TOPM(I,K)      / (BCOMB(4) * TOPPHI(I,K))
    621 END DO
    DO 653 K=1,L
        DO 653 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,4) * (CTMP(I,K+1) - CTMP(I,K))
    653 END DO
    DO 661 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)     + CLDFAC(I,LP1,1) * (  TT(I,L)     *  SORC(I,L,4)                 &
    &            - TWO          *      P(I,L))))  * (SORC(I,LP1,4) -  SORC(I,L,4)))
    661 END DO
! CALCULATION FOR BAND 5 (COMBINED BAND 5)
    DO 701 K=1,L
        DO 701 I=MYIS,MYIE
                 F(I,K) =  H44194M2   * (   APCM(5)    *   X(I,K)  +  BPCM(5)    * Y(I,K))
                FF(I,K) =  H44194M2   * (  ATPCM(5)    *   X(I,K)  + BTPCM(5)    * Y(I,K))
            PHITMP(I,K) =  VAR1(I,K)  * ((((  AG (I,K) *  AG(I,K)) ** 2) ** 2) ** 2)
    701 END DO
    DO 715 I=MYIS,MYIE
    715 END DO
    DO 719 K=2,L
        DO 717 I=MYIS,MYIE
        717 END DO
    719 END DO
    DO 721 K=1,L
        DO 721 I=MYIS,MYIE
            FAC1(I,K)   =  ACOMB(5)     *   TOPM(I,K)
            FAC2(I,K)   =   FAC1(I,K)   *   TOPM(I,K)   / (BCOMB(5)  * TOPPHI(I,K))
              TT(I,K)   =    EXP(HM1EZ  * ( FAC1(I,K)   /   SQRT(ONE +   FAC2(I,K))               &
    &                   + BETACM(5)     * TOTVO2(I,K+1) * SKO2D))
    721 END DO
    DO 753 K=1,L
        DO 753 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,5) * (CTMP(I,K+1) - CTMP(I,K))
    753 END DO
    DO 761 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)         + CLDFAC(I,LP1,1)  * (  TT(I,L)      *  SORC(I,L,5)          &
    &            - TWO              *      P(I,L))))   * (SORC(I,LP1,5)  -  SORC(I,L,5)))
    761 END DO
! CALCULATION FOR BAND 6 (COMBINED BAND 6)
    DO 801 K=1,L
        DO 801 I=MYIS,MYIE
                 F(I,K) =  H44194M2   * (   APCM(6)     *   X(I,K)  +  BPCM(6)    * Y(I,K))
                FF(I,K) =  H44194M2   * (  ATPCM(6)     *   X(I,K)  + BTPCM(6)    * Y(I,K))
    801 END DO
    DO 815 I=MYIS,MYIE
    815 END DO
    DO 819 K=2,L
        DO 817 I=MYIS,MYIE
        817 END DO
    819 END DO
    DO 821 K=1,L
        DO 821 I=MYIS,MYIE
            FAC1(I,K)   =  ACOMB(6)    *   TOPM(I,K)
            FAC2(I,K)   =   FAC1(I,K)  *   TOPM(I,K)   / (BCOMB(6)  * TOPPHI(I,K))
    &                   + BETACM(6)    * TOTVO2(I,K+1) * SKO2D))
    821 END DO
    DO 853 K=1,L
        DO 853 I=MYIS,MYIE
            EXCTS(I,K)= EXCTS(I,K) + SORC(I,K,6) * (CTMP(I,K+1) - CTMP(I,K))
    853 END DO
    DO 861 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)        + CLDFAC(I,LP1,1) * ( TT(I,L)   *  SORC(I,L,6)                 &
    &            + ( HAF           *   DELP(I,L)     * ( TT(I,LM1) * (   P(I,LP1)                 &
    &            *     P(I,L))))   * ( SORC(I,LP1,6) - SORC(I,L,6)))
    861 END DO
! CALCULATION FOR BAND 7 (COMBINED BAND 7)
    DO 901 K=1,L
        DO 901 I=MYIS,MYIE
                 F(I,K) =  H44194M2   * (   APCM(7)    *   X(I,K)   + BPCM (7) * Y(I,K))
                FF(I,K) =  H44194M2   * (  ATPCM(7)    *   X(I,K)   + BTPCM(7) * Y(I,K))
            PHITMP(I,K) =  VAR1(I,K)  * ((((  AG(I,K)  *  AG (I,K)) ** 2) ** 2) ** 2)
            PSITMP(I,K) =  VAR2(I,K)  * (((( AGG(I ,K) * AGG(I,K))  ** 2) ** 2) ** 2)
    901 END DO
    DO 915 I=MYIS,MYIE
    915 END DO
    DO 919 K=2,L
        DO 917 I=MYIS,MYIE
        917 END DO
    919 END DO
    DO 921 K=1,L
        DO 921 I=MYIS,MYIE
            FAC1(I,K)   =   ACOMB(7)    *   TOPM(I,K)
            FAC2(I,K)   =    FAC1(I,K)  *   TOPM(I,K)   / (BCOMB(7)  * TOPPHI(I,K))
    &                    + BETACM(7)    * TOTVO2(I,K+1) * SKO2D))
    921 END DO
    DO 953 K=1,L
        DO 953 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,7) * (CTMP(I,K+1) - CTMP(I,K))
    953 END DO
    DO 961 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)     + CLDFAC(I,LP1,1) * (  TT(I,L)     *  SORC(I,L,7)                 &
    &            - TWO          *      P(I,L))))  * (SORC(I,LP1,7) -  SORC(I,L,7)))
    961 END DO
! CALCULATION FOR BAND 8 (COMBINED BAND 8)
    DO 1001 K=1,L
        DO 1001 I=MYIS,MYIE
                 F(I,K) =  H44194M2   * (   APCM(8)    *   X(I,K)  + BPCM (8)    * Y(I,K))
                FF(I,K) =  H44194M2   * (  ATPCM(8)    *   X(I,K)  + BTPCM(8)    * Y(I,K))
    1001 END DO
    DO 1015 I=MYIS,MYIE
    1015 END DO
    DO 1019 K=2,L
        DO 1017 I=MYIS,MYIE
            TOPM  (I,K) = TOPM  (I,K-1) + PHITMP(I,K)
        1017 END DO
    1019 END DO
    DO 1021 K=1,L
        DO 1021 I=MYIS,MYIE
            FAC1(I,K)   =  ACOMB(8)    *   TOPM(I,K)
            FAC2(I,K)   =   FAC1(I,K)  *   TOPM(I,K)   / (BCOMB(8)  * TOPPHI(I,K))
    &                   + BETACM(8)    * TOTVO2(I,K+1) * SKO2D))
    1021 END DO
    DO 1053 K=1,L
        DO 1053 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K, 8) * (CTMP(I,K+1) - CTMP(I,K))
    1053 END DO
    DO 1061 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)    + CLDFAC(I,LP1,1)  * (  TT(I,L)      *  SORC(I,L,8)                &
    &            - TWO         *      P(I,L))))   * (SORC(I,LP1,8)  -  SORC(I,L,8)))
1061 END DO
! CALCULATION FOR BAND 9 ( 560-670 CM-1; INCLUDES CO2)
    DO 1101 K=1,L
        DO 1101 I=MYIS,MYIE
                 F(I,K) =  H44194M2   * (   APCM(9)    *   X(I,K)  + BPCM (9)    * Y(I,K))
                FF(I,K) =  H44194M2   * (  ATPCM(9)    *   X(I,K)  + BTPCM(9)    * Y(I,K))
    1101 END DO
    DO 1115 I=MYIS,MYIE
    1115 END DO
    DO 1119 K=2,L
        DO 1117 I=MYIS,MYIE
        1117 END DO
    1119 END DO
    DO 1121 K=1,L
        DO 1121 I=MYIS,MYIE
            FAC1(I,K)   =  ACOMB(9)    *   TOPM(I,K)
            FAC2(I,K)   =   FAC1(I,K)  *   TOPM(I,K)   / (BCOMB(9)  * TOPPHI(I,K))
    &                   + BETACM(9)    * TOTVO2(I,K+1) * SKO2D))    * CO2SP1(I,K+1)
    1121 END DO
    DO 1153 K=1,L
        DO 1153 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K, 9) * (CTMP(I,K+1) - CTMP(I,K))
    1153 END DO
    DO 1161 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)     + CLDFAC(I,LP1, 1) * (  TT(I,L)      *  SORC(I,L,9)               &
    &            - TWO          *      P(I,L))))   * (SORC(I,LP1,9)  -  SORC(I,L,9)))
1161 END DO
! CALCULATION FOR BAND 10 (670-800 CM-1; INCLUDES CO2)
    DO 1201 K=1,L
        DO 1201 I=MYIS,MYIE
                 F(I,K) =  H44194M2   * (   APCM(10)   *   X(I,K) +  BPCM(10)    * Y(I,K))
                FF(I,K) =  H44194M2   * (  ATPCM(10)   *   X(I,K) + BTPCM(10)    * Y(I,K))
    1201 END DO
    DO 1215 I=MYIS,MYIE
    1215 END DO
    DO 1219 K=2,L
        DO 1217 I=MYIS,MYIE
        1217 END DO
    1219 END DO
!---TT IS THE CLOUD-FREE CTS TRANSMISSION FUNCTION
    DO 1221 K=1,L
        DO 1221 I=MYIS,MYIE
             FAC1(I,K) = ACOMB(10)   *   TOPM(I,K)
             FAC2(I,K) =  FAC1(I,K)  *   TOPM(I,K)  / (BCOMB(10) * TOPPHI(I,K))
               TT(I,K) =   EXP(HM1EZ *  (FAC1(I,K)  /   SQRT(ONE +   FAC2(I,K))                   &
    &                  + BETACM(10)  * TOTVO2(I,K+1) * SKO2D))   * CO2SP2(I,K+1)
            CTMP(I,K+1)=TT(I,K)*CLDFAC(I,K+1,1)
    1221 END DO
    DO 1253 K=1,L
        DO 1253 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,10) * (CTMP(I,K+1) - CTMP(I,K))
    1253 END DO
    DO 1261 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)    + CLDFAC(I,LP1,1) * (  TT(I,L)      *  SORC(I,L,10)                &
    &             +(HAF        *   DELP(I,L)     * (  TT(I,LM1)    * (   P(I,LP1)                 &
    &             -PRESS(I,L)) +     TT(I,L)     * (   P(I,LP1)    + PRESS(I,L)                   &
    &             -TWO         *      P(I,L))))  * (SORC(I,LP1,10) -  SORC(I,L,10)))
1261 END DO
! CALCULATION FOR BAND 11 (800-900 CM-1)
    DO 1301 K=1,L
        DO 1301 I=MYIS,MYIE
                 F(I,K) =  H44194M2  * ( APCM(11)   *   X(I,K)  +  BPCM(11)   * Y(I,K))
                FF(I,K) =  H44194M2  * (ATPCM(11)   *   X(I,K)  + BTPCM(11)   * Y(I,K))
            PHITMP(I,K) =  VAR1(I,K) *(((( AG(I,K)  *  AG(I,K)) ** 2) ** 2) ** 2)
            PSITMP(I,K) =  VAR2(I,K) *(((( AGG(I,K) * AGG(I,K)) ** 2) ** 2) ** 2)
    1301 END DO
    DO 1315 I=MYIS,MYIE
    1315 END DO
    DO 1319 K=2,L
        DO 1317 I=MYIS,MYIE
            TOPPHI(I,K) =TOPPHI(I,K-1) + PSITMP(I,K)
        1317 END DO
    1319 END DO
    DO 1321 K=1,L
        DO 1321 I=MYIS,MYIE
            FAC1(I,K) =  ACOMB(11)    *   TOPM(I,K)
            FAC2(I,K) =   FAC1(I,K)   *   TOPM(I,K)   / (BCOMB(11) * TOPPHI(I,K))
    &                 + BETACM(11)    * TOTVO2(I,K+1) * SKO2D))
    1321 END DO
    DO 1353 K=1,L
        DO 1353 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,11) * (CTMP(I,K+1) - CTMP(I,K))
    1353 END DO
    DO 1361 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)    + CLDFAC(I,LP1,1) * (  TT(I,L)      *  SORC(I,L,11)                &
    &            - TWO         *      P(I,L))))  * (SORC(I,LP1,11) -  SORC(I,L,11)))
1361 END DO
! CALCULATION FOR BAND 12 (900-990 CM-1)
    DO 1401 K=1,L
        DO 1401 I=MYIS,MYIE
                 F(I,K) =  H44194M2  * (  APCM(12)   *   X(I,K) +  BPCM(12)    * Y(I,K))
                FF(I,K) =  H44194M2  * ( ATPCM(12)   *   X(I,K) + BTPCM(12)    * Y(I,K))
    1401 END DO
    DO 1415 I=MYIS,MYIE
    1415 END DO
    DO 1419 K=2,L
        DO 1417 I=MYIS,MYIE
        1417 END DO
    1419 END DO
    DO 1421 K=1,L
        DO 1421 I=MYIS,MYIE
            FAC1(I,K)   =  ACOMB(12)   *   TOPM(I,K)
            FAC2(I,K)   =   FAC1(I,K)  *   TOPM(I,K)   / (BCOMB(12) * TOPPHI(I,K))
    &                   + BETACM(12)   * TOTVO2(I,K+1) * SKO2D))
    1421 END DO
!---EXCTS IS THE CTS COOLING RATE ACCUMULATED OVER FREQUENCY BANDS
    DO 1453 K=1,L
        DO 1453 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,12) * (CTMP(I,K+1) - CTMP(I,K))
    1453 END DO
!---GXCTS IS THE EXACT CTS TOP FLUX ACCUMULATED OVER FREQUENCY BANDS
    DO 1461 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)    + CLDFAC(I,LP1,1) * (  TT(I,L)      * SORC(I,L,12)                 &
    &            - TWO         *      P(I,L))))  * (SORC(I,LP1,12) -  SORC(I,L,12)))
1461 END DO
! CALCULATION FOR BAND 13 (990-1070 CM-1; INCLUDES O3))
! COMPUTE TEMPERATURE-CORRECTED !   OPTICAL PATH AND MEAN PRESSURE FOR A LAYER (PHITMP,PSITMP)
    DO 1501 K=1,L
        DO 1501 I=MYIS,MYIE
                 F(I,K) =  H44194M2  *(   APCM(13)   *   X(I,K)  + BPCM(13)    * Y(I,K))
                FF(I,K) =  H44194M2  *(  ATPCM(13)   *   X(I,K)  + BTPCM(13)   * Y(I,K))
    1501 END DO
    DO 1515 I=MYIS,MYIE
    1515 END DO
    DO 1519 K=2,L
        DO 1517 I=MYIS,MYIE
        1517 END DO
    1519 END DO
    DO 1521 K=1,L
        DO 1521 I=MYIS,MYIE
            FAC1(I,K)   =  ACOMB(13)   *   TOPM(I,K)
            FAC2(I,K)   =   FAC1(I,K)  *   TOPM(I,K)   / (BCOMB(13) * TOPPHI(I,K))
    &                   + BETACM(13)   * TOTVO2(I,K+1) * SKO2D      + TO3SPC(I,K)))
    1521 END DO
    DO 1553 K=1,L
        DO 1553 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,13) * (CTMP(I,K+1) - CTMP(I,K))
    1553 END DO
    DO 1561 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)    + CLDFAC(I,LP1,1) * (  TT(I,L)      *  SORC(I,L,13)                &
    &            - TWO         *      P(I,L))))  * (SORC(I,LP1,13) -  SORC(I,L,13)))
1561 END DO
! CALCULATION FOR BAND 14 (1070-1200 CM-1)
    DO 1601 K=1,L
        DO 1601 I=MYIS,MYIE
                 F(I,K) = H44194M2   * (   APCM(14)   *   X(I,K)  + BPCM(14)    * Y(I,K))
                FF(I,K) = H44194M2   * (  ATPCM(14)   *   X(I,K)  + BTPCM(14)   * Y(I,K))
    1601 END DO
    DO 1615 I=MYIS,MYIE
    1615 END DO
    DO 1619 K=2,L
        DO 1617 I=MYIS,MYIE
        1617 END DO
    1619 END DO
    DO 1621 K=1,L
        DO 1621 I=MYIS,MYIE
            FAC1(I,K)   =  ACOMB(14)   *   TOPM(I,K)
            FAC2(I,K)   =   FAC1(I,K)  *   TOPM(I,K)   / (BCOMB(14) * TOPPHI(I,K))
    &                   + BETACM(14)   * TOTVO2(I,K+1) * SKO2D))
    1621 END DO
    DO 1653 K=1,L
        DO 1653 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) + SORC(I,K,14) * (CTMP(I,K+1) - CTMP(I,K))
    1653 END DO
    DO 1661 I=MYIS,MYIE
        GXCTS(I) = GXCTS(I)    + CLDFAC(I,LP1,1) * (  TT(I,L)      *  SORC(I,L,14)                &
    &            - TWO         *      P(I,L))))  * (SORC(I,LP1,14) -  SORC(I,L,14)))
1661 END DO
! OBTAIN CTS FLUX AT THE TOP BY INTEGRATION OF HEATING RATES AND USING CTS FLUX AT THE BOTTOM
! (CURRENT VALUE OF GXCTS). NOTE THAT THE PRESSURE QUANTITIES AND CONVERSION FACTORS HAVE NOT
! BEEN INCLUDED EITHER IN EXCTS OR IN GXCTS. THESE CANCEL OUT, THUS REDUCING COMPUTATIONS
    DO 1731 K=1,L
        DO 1731 I=MYIS,MYIE
            GXCTS(I) = GXCTS(I) - EXCTS(I,K)
1731 END DO
! NOW SCALE THE COOLING RATE (EXCTS) BY INCLUDING THE PRESSURE FACTOR (DELP) AND THE CONVERSION
! FACTOR (RADCON)
    DO 1741 K=1,L
        DO 1741 I=MYIS,MYIE
            EXCTS(I,K) = EXCTS(I,K) * RADCON * DELP(I,K)
    1741 END DO
! THIS IS THE END OF THE EXACT CTS COMPUTATIONS; AT THIS POINT EXCTS HAS ITS APPROPRIATE VALUE.
! COMPUTE APPROXIMATE CTS HEATING RATES FOR 15UM AND 9.6 UM BANDS (CTSO3)
    DO 1711 K=1,L
        DO 1711 I=MYIS,MYIE
            CTMP2(I,K+1) = CO2SP(I,K+1) * CLDFAC(I,K+1,1)
            CTMP3(I,K+1) = TO3SP(I,K)   * CLDFAC(I,K+1,1)
    1711 END DO
    DO 1701 K=1,L
        DO 1701 I=MYIS,MYIE
           CTSO3(I,K) = RADCON       *   DELP(I,K)   * (CSOUR(I,K) * (CTMP2(I,K+1) - CTMP2(I,K))  &
    &                 + SORC(I,K,13) * (CTMP3(I,K+1) -  CTMP3(I,K)))
    1701 END DO
    RETURN
    END SUBROUTINE SPA88
However,  my equivalent variables are constant changing its values,
My question is, everytime any of this variables changes its value along the code i must do again the transfer function ?
Exist another easier way to do it ?
Thank you very much for your attention
mecej4
Since you have not divulged the contents of the include files and the sources of the modules that are used, the following comments have to be somewhat vague and general.
TRANSFER and EQUIVALENCE are not equivalent. EQUIVALENCE is a declaration that results in the same memory being accessible with different variable names. Changing values using any of these names changes the values of all the variables that are equivalenced.
TRANSFER, on the other hand, is used in expressions that you may assign as values to variables. Only the variable to the left of the assignment operator '=' has the value changed. If you had n equivalenced variables in a set in the old program version, you may need n-1 assignments with TRANSFER to make corresponding assignments in the new version.  You will need to examine whether or not this has been done in your program.
Luis_Thiago_L_
Sorry about not posting the full sources.
Its because my program is really big.
What I`m trying to do is convert all COMMON block into MODULES but in some parts I can`t use modules because its variables are used in EQUIVALENCES.
I`m trying to find the best way to replace them.
mecej4
You can equivalence two or more module variables in the module declarations part. For example:
module xyz
   implicit none
   integer :: i1,i2,i3
   equivalence(i1,i3)
end module
Although eliminating COMMON and EQUIVALENCE is a worthwhile goal, there is no need to do both in one stroke.
What I am suggesting is to remove COMMON, while retaining EQUIVALENCE. After that has been successfully accomplished and your new program tested for correct functioning, you can focus your attention on removing the equivalenced variables, using TRANSFER or other strategies.
