29653 Discussions
Equivalent of `module`variable command if using idb -gdb
nicolas_rousselon
When using idb, module's variables are accessed using `module`variable. What about when using idb -gdb?
Nicolas
Intel_C_Intel
The Intel Debugger release notes state:
Fortran modules
A globally defined Fortran module should be rescoped with a double percent (%%) when referred to. For example, to set a breakpoint in the subroutine bar contained in a globally defined module foo, do
(idb) stop in foo%%bar
Please refer to the following section in the manual for the rescoping syntax:
Looking Around the Code, the Data and Other Process Information > Looking at the Data > The print Command
That syntax works in both DBX and GDB command modes.
Please let me know if there's something more you need in this regard.
-- G
