Error #7002
doriat__aurelien
Dear all,
I am beginning with Linux computer and I would use a home code for a summer job. The code is written in fortran and I have to use Intel Fortran Compiler, but, when I compile the code, an error is detected. This is the errors :
doriat@doriat-X555LB:~/lusie$ make lusie
ifort  -c -g -check all -nofor-main InputModule_LUSIE.f90
InputModule_LUSIE.f90(46): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [INHOMOGENEOUS]
      USE INHOMOGENEOUS
InputModule_LUSIE.f90(277): error #6404: This name does not have a type, and must have an explicit type.   [INHOM]
         ldest_ptrs(1)%ptrl => inhom;      ldest_name(1) = 'inhom'
InputModule_LUSIE.f90(277): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [INHOM]
InputModule_LUSIE.f90(278): error #6404: This name does not have a type, and must have an explicit type.   [LINEAR]
         ldest_ptrs(2)%ptrl => LINEAR;     ldest_name(2) = 'LINEAR'
InputModule_LUSIE.f90(278): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [LINEAR]
InputModule_LUSIE.f90(279): error #6404: This name does not have a type, and must have an explicit type.   [PARABOLIC]
         ldest_ptrs(3)%ptrl => PARABOLIC;  ldest_name(3) = 'PARABOLIC'
InputModule_LUSIE.f90(279): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [PARABOLIC]
InputModule_LUSIE.f90(280): error #6404: This name does not have a type, and must have an explicit type.   [FERMI]
         ldest_ptrs(4)%ptrl => FERMI;      ldest_name(4) = 'FERMI'
InputModule_LUSIE.f90(280): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [FERMI]
InputModule_LUSIE.f90(281): error #6404: This name does not have a type, and must have an explicit type.   [CYLINDER_DEV]
         ldest_ptrs(5)%ptrl => cylinder_dev;   ldest_name(5) = 'cylinder_dev'
InputModule_LUSIE.f90(281): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [CYLINDER_DEV]
InputModule_LUSIE.f90(282): error #6404: This name does not have a type, and must have an explicit type.   [TURB_MIX]
         ldest_ptrs(6)%ptrl => TURB_MIX;   ldest_name(6) = 'TURB_MIX'
InputModule_LUSIE.f90(282): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [TURB_MIX]
InputModule_LUSIE.f90(283): error #6404: This name does not have a type, and must have an explicit type.   [PHI_MAX]
         rdest_ptrs(1)%ptrr => PHI_MAX;    rdest_name(1) = 'PHI_MAX'
InputModule_LUSIE.f90(283): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [PHI_MAX]
InputModule_LUSIE.f90(284): error #6404: This name does not have a type, and must have an explicit type.   [PHI_MIN]
         rdest_ptrs(2)%ptrr => PHI_MIN;    rdest_name(2) = 'PHI_MIN'
InputModule_LUSIE.f90(284): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [PHI_MIN]
InputModule_LUSIE.f90(285): error #6404: This name does not have a type, and must have an explicit type.   [SOI]
         rdest_ptrs(3)%ptrr => SOI;        rdest_name(3) = 'SOI'
InputModule_LUSIE.f90(285): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [SOI]
InputModule_LUSIE.f90(286): error #6404: This name does not have a type, and must have an explicit type.   [Y_0]
         rdest_ptrs(4)%ptrr => Y_0;        rdest_name(4) = 'Y_0'
InputModule_LUSIE.f90(286): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [Y_0]
InputModule_LUSIE.f90(287): error #6404: This name does not have a type, and must have an explicit type.   [DY]
         rdest_ptrs(5)%ptrr => dY;         rdest_name(5) = 'dY'
InputModule_LUSIE.f90(287): error #6796: The variable must have the TARGET attribute or be a subobject of an object with the TARGET attribute, or it must have the POINTER attribute.   [DY]
compilation aborted for InputModule_LUSIE.f90 (code 1)
Makefile:123 : la recette pour la cible « InputModule_LUSIE.o » a échouée
make: *** [InputModule_LUSIE.o] Erreur 1
I think that there is a porblem with the compiler or Linux.
Thank in advance for your help,
Aurélien !
AThar2
The file “InputModule_LUSIE.f90” is using a module through the use statement. That module must be compiled before you can compile your InputModule_LUSIE.f90
I think you should revise your makefile and make sure that module file “inhomogenous” comes before.
doriat__aurelien
Thanks you so muche. In fact, this is a home code, and I don't know if there is a makefile. It is look like a .o folders ?
jimdempseyatthecove
If your make file is not creating inhomogenous.mod (and inhomogenous.o and/or inhomogenous.a), then look at the 3rd party distribution for the library you are using. In its installation path you should find inhomogenous.mod. The path to this file must be included in the INCLUDE paths. You may have a similar issue with inhomogenous.o, and if applicable inhomogenous.a (though this would require an inclusion in LD_LIBRARY_PATH).
Jim Dempsey
