Error Code lists?
lklawrie1
Specifically I'm interested in IOSTAT error numbers but also would be intested in RunTime errors. -- That is, a long explanation string for the error code.
Surely, they are not standard between compilers (i.e. Intel vs Lahey?)
If someone can point me to the Intel listing, I'd appreciate it. (I know about iosdef.for but that's a bit cryptic and may not be complete?)
Linda
No, error codes are not standard across compilers.
Run-time error numbers are documented in the User's Guide Volume 1, Reference Information, Run-Time Error Messages.
lklawrie1
Thanks, as always, Steve.
I had looked in all the other documents and searched, but yes -- did find what I needed from the User Guide documents.
Are they at least standard between CVF and IVF?
Linda
Pretty much so, yes. Any error code from CVF should be the same number in Intel Fortran 8 or higher.
