Error Debugger
tdigital1
Please I need help.
1. Product :
Intel Visual Fortran Compiler 8.0, Professional Edition, for Windows
2. Problem :
When start the program Intel debugger (GUI) from the Windows:
This application has failed to start because MSVCR71.dll was not found.
Re-installing the application may fix this problem.
Thank very much,
Alfredo
Please say in more detail how you start the debugger. Do you have Microsoft Visual C++ installed?
tdigital1
Steve , thanks again by your support.
I talked with you two years ago ( I live in Sao Paulo- Brazil).
I working with Visual Fortran .
The customer don't have Microsoft Visual C++ installed.
Is it necessary ? the customer start the Debugger and the form it appears
and after it disappears with the mensagem : This application has failed
to start because MSVCR71.dll .
Thanks ,
Alfredo
If the customer is using the free Microsoft Visual C++ Toolkit, MSVCR71.DLL is found in the BIN folder in that kit. It can be copied to the WindowsSystem32 folder.
