29657 Discussions
Error: The CALL statement is invoking a function subprogram as a subroutine.
Alex_S_5
Why isthatthe Compaq Visual Fortran compiles this code:
integer function ifun()
ifun=111
end
program test
call ifun()
!i=ifun()
end
OK. Whilethe Intel Visual Fortran 10.0 displays the error:
If I uncomment
i=ifun()
and comment call ifun() IVF, understandably,compiles it OK.
I was under the impression that Fortran allows functions to be call as subroutines
(the pgplot library that we usestopped compiling because of this).
An input from more experienced colleagues is much appreciated.
No, the Fortran language does NOT allow this. CVF allowed it under some cirucmstances, but we realized that some of the cases where this was allowed could still cause problems such as floating stack corruption. The number of cases where it was safe was outweighed by the number where it wasn't, and we decided to bite the bullet and disable this "feature" for the Intel compilers.
Alex_S_5
Thanks Steve for straightening it out.
Intel guysmay want to edit the following web page:
http://www.intel.com/support/performancetools/libraries/mkl/sb/cs-017175.htm
where it is explicitly stated that Fortran DOES allow to "call functions
as though the were subroutines...":
Because Fortran lets you call functions as though they were subroutines, however, there is a mechanism for returning the complex value correctly when the function is called from a C program. When a Fortran function is called as a subroutine, the return value shows up as the first parameter in the calling sequence - a feature that can be exploited by the C programmer.
This and the fact that all the other Fortran compilers I tried in the past allowed that
got me confused.
Alex
Thanks - I'll ask that that page be corrected.
mecej4
Steve, they seem to need a reminder!
Ok, will see what I can do.
Nowadays I can fix this myself - and I have done so.
