29359 Discussions
Error: There is no matching specific subroutine for this generic subroutine call
bthekid
Hi, im new in this forum
Just want to help me fix a fortran program compiler error concernin "Error: There is no matching specific subroutine for this generic subroutine call"
My program radiation.f90 USED total_fluxes and spectrum of fluxes.f90
Here his apart of radiation.f90:
USE precision
USE rad_field_mod
USE fluxes
! USE total_flux
! USE spectrum
IMPLICIT NONE
PRIVATE
PUBLIC :: radiation
SAVE
INTEGER :: mupts
REAL(KIND=real_opt), ALLOCATABLE, DIMENSION(:) :: cosines
REAL(KIND=real_opt), ALLOCATABLE, DIMENSION(:,:,:,:) :: f
REAL(KIND=real_opt), ALLOCATABLE, DIMENSION(:,:,:) :: fb
REAL(KIND=real_opt), ALLOCATABLE, DIMENSION(:,:) :: r
CALL total_flux(f(:,:,:,1),cosines,waveln(1:nwav,1,1),(180.0-theta_f),&
(180.0), flx)
CALL total_flux(f(:,:,1,:), cosines, waveln(1:nwav,1,1), (180.0-theta_f), &
(180.0), flx)
CALL spectrum(f(:,:,1,:),cosines,(180.-theta_s),180.0,spec)
CALL spectrum(f(:,:,:,1),cosines,(180.-theta_s),180.0,spec)
total_flux and spectrum are define in fluxes.f90like dat:
USE precision
USE integrate_mod
IMPLICIT NONE
SAVE
PRIVATE
PUBLIC :: total_flux, spectrum
REAL(KIND=real_opt), PARAMETER :: &
degrees_to_radians=1.745329238474369D-2, &
two_pi=6.283185307179586D0
INTERFACE total_flux
MODULE PROCEDURE total_flux
END INTERFACE
INTERFACE spectrum
MODULE PROCEDURE spectrum
END INTERFACE
CONTAINS
SUBROUTINE total_flux(f, mu, lambda, t1, t2, flux)
REAL(KIND=real_opt), DIMENSION(:,:,:), INTENT(IN) :: f
REAL(KIND=real_opt), DIMENSION(SIZE(f,2)), INTENT(IN) :: mu
REAL(KIND=real_opt), DIMENSION(SIZE(f,1)), INTENT(IN) :: lambda
REAL(KIND=real_opt), INTENT(IN) :: t1, t2
REAL(KIND=real_opt), DIMENSION(SIZE(f,3)), INTENT(OUT) :: flux
INTEGER :: stat
REAL(KIND=real_opt) :: mu1, mu2
REAL(KIND=real_opt), DIMENSION(SIZE(f,2),SIZE(f,3)) :: integrand
INTEGER :: nwav, nmu, nx, i, j
mu1 = COS(degrees_to_radians * t2)
mu2 = COS(degrees_to_radians * t1)
flux = 0.
IF( mu1>=MAXVAL(mu) .OR. mu2<=MINVAL(mu) ) THEN
PRINT '(A)', 'TOTAL_FLUX : Integration limits lie outside the range &
&of ''mu''.'
PRINT '(2(A,F8.4))', &
'mu1 = ', mu1, ' MAXVAL(mu) = ', MAXVAL(mu), &
'mu2 = ', mu2, ' MINVAL(mu) = ', MINVAL(mu)
RETURN
ENDIF
nwav=SIZE(f,1)
nmu=SIZE(f,2)
nx=SIZE(f,3)
! Integrate over the wavelengths
DO i=1, nmu
DO j=1, nx
! integrand(i,j) = integrate(f(:,i,j),lambda,lambda(1),lambda(nwav))
integrand(i,j) = trapezium(f(:,i,j),lambda,lambda(1),lambda(nwav),stat)
ENDDO
ENDDO
! Integrate over z-direction cosines
DO i=1, nx
! Need to multiply the integrand by mu to account for the fact that
! photons incident at a larger angle are spread over a larger area
!flux(i) = integrate(integrand(:,i) * ABS(mu),mu,mu1,mu2)
flux(i) = trapezium(integrand(:,i) * ABS(mu),mu,mu1,mu2,stat)
ENDDO
! Integrate over the azimuthal angle
flux = two_pi * flux
END SUBROUTINE total_flux
SUBROUTINE spectrum(f, mu, t1, t2, spec)
IMPLICIT NONE
REAL(KIND=real_opt), DIMENSION(SIZE(f,1),SIZE(f,3)) :: spec
INTEGER :: stat
INTEGER :: nwav, nx, i, j
nwav = SIZE(f,1)
nx = SIZE(f,3)
! Integrate over the z-direction cosines
DO i=1, nwav
DO j=1, nx
!spec(i,j) = integrate(f(i,:,j) * ABS(mu),mu,mu1,mu2)
spec(i,j) = trapezium(f(i,:,j) * ABS(mu),mu,mu1,mu2,stat)
ENDDO
ENDDO
spec = two_pi * spec
END SUBROUTINE spectrum
END MODULE fluxes
and the compilator result is:
Compiling Fortran...
D:\EBF\Progammes\Parade\v2.2.1\radiation.f90
D:\EBF\Progammes\Parade\v2.2.1\radiation.f90(270) : Error: There is no matching specific subroutine for this generic subroutine call. [TOTAL_FLUX]
D:\EBF\Progammes\Parade\v2.2.1\radiation.f90(282) : Error: There is no matching specific subroutine for this generic subroutine call. [TOTAL_FLUX]
D:\EBF\Progammes\Parade\v2.2.1\radiation.f90(337) : Error: There is no matching specific subroutine for this generic subroutine call. [SPECTRUM]
D:\EBF\Progammes\Parade\v2.2.1\radiation.f90(352) : Error: There is no matching specific subroutine for this generic subroutine call. [SPECTRUM]
jimdempseyatthecove
In module fluxes try removing
END INTERFACE
INTERFACE spectrum
END INTERFACE
Those two subroutines are declared in the CONTAINS section of module fluxes so their interfaces will be known to those that USE FLUXES (without explicitly declaring an INTERFACE).
The source to the problem is you have the same name for the interface as you have for the subroutine. When you have only one subroutine for an interface leave the interface name blank (or mark it up with some text)
INTERFACE
END INTERFACE
INTERFACE
END INTERFACE
or
INTERFACE total_flux_interface
END INTERFACE
INTERFACE spectrum_interface
END INTERFACE
When using generic interfaces you provide a single generic name on (after)the INTERFACE then you can declare multiple subroutines with different names that are typically not directly accessed. The signature of the arguments are used to select which enclosed subroutine (or function) declarations match.
interface mySum
subroutine mySum_float(S,A,B)
real(4) :: S,A,B
end subroutine mySum_float
subroutine mySum_double(S,A,B)
real(8) :: S,A,B
end subroutine mySum_double
end interface mySum
Now later in your code you can call the same interface name "mySum" and the types and numbers ofarguments you specify select "mySum_float", "mySum_double", or error out with "no matching specific subroutine for this specific generic interface".
Jim Dempsey
Jim Dempsey
It is perfectly legal and fine for the generic name and a specific name to be the same. The real problem here is that the ranks of the arguments don't match. For example, in the calls to total_flux, the first argument, f, is rank 4, but the corresponding dummy argument in total_flux, f, is rank 3. The second argument also has mismatched ranks. Solve the rank mismatch and the issues will probably go away.
When you call a generic, there has to be one and only one specific procedure which matches the supplied arguments in type, kind and rank.
bthekid
Thanks for your response. But there is no arg problem because there are to f function.. one defined in fluxes with 3 arg and other in radiation.f90 with 4 arg.
For jimmy's suggestion, i tried it but no change.
I see only one total_flux function. Are you saying there's another declaration of the generic in a module you didn't show?
bthekid
in fluxes.f90
and
INTEGER :: statINTEGER :: mupts
in radiation.f90...
Im not the author of this program so i dont know why there is to different functions...
Anyway , i've tried to replace the f-function by another (waveln(:,:,:) for exapmle)... same errors
In radiation.f90 you are declaring variables. In flux.f90, you are declaring procedure dummy arguments. From what you have posted, there is only one actual procedure total_flux, which is the only possible resolution of a call to the generic total_flux. The actual procedure declares the first argument as an array of three dimensions, but you're trying to pass it an array of four dimensions. This is not allowed.
I don't know why you refer to "f-function". There is no function f in this code. f is an array in radiation.f90.
I can't advise you on what to change here, as I don't know your application. You must, however, ensure that the arguments in a call match the called routine arguments in type, kind and rank.
bthekid
Thank you Steve,
i understand now ( the difference between declaring variables and procedure; im a fortran novice)
Im not the author of this program, so i dont understand all procedures... i just try to make an executable (radiation.exe)
I've allready tried to pass it an array of three arguments..
I suggest that you contact the code's author and ask for assistance. To correctly solve the problem requires much more context than what you have shown here. If the program is not terribly large, perhaps you can create a ZIP of the project and sources and attach it to a reply here.
bthekid
I tried to contact teh author but i think he still not work on the project.
I sent you a zip of the folder containing the fortran files, if you can help me
Thank you again
I have not received anything from you. You can use the instructions in the link below to attach a ZIP file.
