29637 Discussions
Error Using IFPORT in x64 in Windows
Neels
New Contributor II
I use IFPORT successfully in Windows and x86 but get the following error in X64, is it not compatible or should I use a different library?
andrew_4619
yours args are wrong I would say so the call does not match any defined interface for that routine.
andrew_4619
Neels
New Contributor II
Thank you, yes I had "Handle" as a plain integer.
