Error at building program
bernardopuc
Hi all,
I am using Intel Visual Fortran Compiler for Windows and MVS 2008 for editing and building projects.
I have a program code in Fortran tha compiles without errors, but when I build a project, it returns the following message:
1>------ Build started: Project: Teste Rotina_barnes_cressman, Configuration: Debug Win32 ------
1>Linking...
1>barnes.obj : error LNK2019: unresolved external symbol _DY referenced in function _MAIN__
1>Debug\\Teste Rotina_barnes_cressman.exe : fatal error LNK1120: 1 unresolved externals
1>
1>Build log written to "file://C:\\Users\\Administrador\\Documents\\Visual Studio 2008\\Projects\\Teste Rotina_barnes_cressman\\Teste Rotina_barnes_cressman\\Debug\\BuildLog.htm"
1>Teste Rotina_barnes_cressman - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
How can I solve this?
Thank you all!
You have a call to a procedure named DY that you do not define.  Sometimes this is caused by referencing an array that is not declared - the compiler assumes that a reference of the form DY(1) is a function call and not an array if it is not declared as an array.
bernardopuc
Ok Thanks!
I've tried to identify this array in my code and it's used only once, in the main program.
In this code that I'm working, there are two subroutines that don't call that array.
Here is the code (You can see where this array is declared):
program BARNES
c
c This program performs an objective analysis of a scalar
c field using Barnes' scheme. It can also be apllied to
c a vector field provided each component is treated
c separately. The program doesn't include any bad data
c verification since this depends on the field to be analysed.
c A trivial setup has ,however,been arranged in subroutine
c INTERP.
c
parameter( ns = 85,l = 27,m = 15 )
common /dist/x(ns),y(ns),ib(ns),jb(ns),xg(l),yg(m)
real value(ns),ylat(ns),xlong(ns),hg(l,m)
data wlong,slat,dx,dy/97.,39.,0.5,0.5/
c
c variable definitions.
c
c ns : number of station data
c l : east-west dimension of the analysis domain
c m : north-south dimension of the analysis domain
c slat : southernmost latitude
c wlong : westernmost longitude
c dx,dy : grid size in the x and y directions
c
open (10,file='station.dat',status='old')
open (12, file='out6.dat ',status='unknown')
c
c Read station data
c ii : station number
c ylat : station latitude
c xlong : station longitude
c value : station value of the field to analyse
c
81 format(2x,i2,2x,3f10.2)
do 5200 i = 1, ns
read (10,81)ii,ylat(i),xlong(i),value(i)
5200 continue
c
c Compute the coordinates of the stations(meters) from the origin
c (wlong,slat). Also find the coordinates of the closest grid point
c to the station ,based on the following relationship :
c iposx = ifact*difx + 1 , and
c iposy = jfact*dify + 1 , where
c ifact and jfact are the number of grid points within 1 degrees of
c latitude ,and can be expressed as , ifact = integer(1./dx) and
c jfact = integer(1./dy). Difx,dify are the absolute values of the
c differences in degrees between the station and the origin,
c in the x,y directions,respectively.
c
do 5202 i = 1, ns
x(i) = (wlong-xlong(i))*cos(ylat(i))*1.111e5
y(i) = (ylat(i)-slat)*1.111e5
ib(i) = 2*(wlong-xlong(i)) + 1
jb(i) = 2*(ylat(i) - slat) + 1
5202 continue
c
c Compute the distance of all grid points from origin.
c
do 5204 i = 1, l
xg(i) = (i-1)*1.111e5*dx
5204 continue
do 5206 j = 1, m
yg(j) = (j-1)*1.111e5*dy
5206 continue
c
c Perform the objective analysis .
c
call OBJAN2 (value,hg,L,M,1)
c
c Write outputs
c
write (12,1000) ((hg(i,j),i=1,l),j=1,m)
1000 format (15f8.2)
stop
end
subroutine OBJAN2 (value,hg,ix,iy,number)
c
c This subroutine performs an objective analysis
c following barnes method .
c
parameter (ns = 85, l = 27, m = 15)
common /dist/ x(ns),y(ns),ib(ns),jb(ns),xg(l),yg(m)
real value(ns),h(ns),g(L,M),hg(ix,iy)
c
c Set the number of passes
c
nop = 1
do 5210 n = 1, nop
call INTERP (value,hg,ix,iy,number)
c
c For the first iteration,the observed values are stored in h.
c
if (n.eq.1) then
do 5211 k = 1, ns
h(k) = value (k)
5211 continue
do 5212 i = 1, ix
do 5212 j = 1, iy
g(i,j) = hg(i,j)
5212 continue
else
c
c Second and third iterations.
c
do 5213 i = 1, ix
do 5213 j = 1, iy
g(i,j) = g(i,j) + hg(i,j)
5213 continue
endif
c
c Fourth iteration .
c
if (n.eq.4) then
do 5214 i = 1, ns
value(k) = h(k)
5214 continue
do 5215 i = 1, ix
do 5215 j = 1, iy
hg(i,j)= g(i,j)
5215 continue
else
do 5216 k = 1, ns
value(k) = h(k)-0.25*(g(ib(k),jb(k))+g(ib(k)+1,jb(k))
& +g(ib(k),jb(k)+1)+g(ib(k)+1,jb(k)+1))
5216 continue
endif
5210 continue
return
end
subroutine INTERP (value,hg,ix,iy,number)
c
c This subroutine Compute the weights for Barnes' scheme
c and the values of the interpolated functions.
c
parameter(ns=85,l=27,m=15)
real value(ns),hg(ix,iy)
21 format(10f8.2)
c
c Define the radius of influence .
c
r = 2.75e5
rsqr = r*r
do 5220 i = 1, ix
do 5220 j = 1, iy
suma = 0.
sumb = 0.
do 5221 k = 1,ns
c
c Compute distance between grid point and station .
c
dist2 = (x(k)-xg(i)*cos(39.+dy(j-1)))**2+(y(k)-yg(j))**2
c
c Set an arbitary test.Critical value needs to be
c changed corresponding to input data set.
c
if (value(k).gt.5000.) go to 5221
c
c Check if the station is within the
c radius of influence .
c
if (dist2.gt.rsqr) go to 5221
c
c compute the weigths (eq. 5.28)
c
wgt = exp(-4.*dist2/rsqr)
c
c compute the interpolated value (eq. 5.29)
c
prod = value(k)*wgt
suma = suma+wgt
sumb = sumb+prod
5221 continue
hg(i,j) = sumb/suma
5220 continue
return
end
Please, help me! I'm new at programming.
Thank you!
TimP
Early in the program, you use dy as a scalar variable, and that usage looks OK.  Then, in subroutine interp, without ever declaring it, you apparently use an array dy(0:iy-1).  There is no context here to guess where that should have come from; the compiler assumes an external function subprogram rather than an array.
bernardopuc
Thank you so much for your help!
Actually, in this expression is missing a * operator, I put it and the code runs without problems.
But, when I ran for the second time, it shows the error: error #6634: The shape matching rules of actual arguments and dummy arguments have been violated.
I've checked all the variables and seems to be OK, but I can't see where the arguments mismatch.
Could you please help me again?
Another question, at the beginnig of the code I wrote a line code tha opens and writes the results in a new archive (out6.dat). I can't find the output in my workspace, where can I find it?
Thank you all!!!
Do a Build > Rebuild Solution and the error should go away.
The data file will be in the same folder as the project file (.vfproj).  You can change this with the project property Debugging > Working Directory.
