Error compilation with ifort 8.1
frederic_bouyer
Hello Everybody,
When compiling with ifort 8.1 (on my PC/ReadHat), I get the following error message :
fortcom: Error: file.f, line 10: Syntax error, found ''' when expecting one of: ( * :: , ...
. (cnfigtb(l,nsm,is),sym(l),'(',qPAO(l,nsm),')',
I didn't get error message with that code when compiling with ifort 8.0.
Do I have to put/check one new option ?
Frederic
Are you using the latest compiler, 8.1.024? If so, this may be a bug that will be fixed in the next update. A workaround is to continue the line differently - add a continuation before the '('- I think that will work.
frederic_bouyer
Yes, it is. version 8.1.024 ...
BTW, I turned to my old compiler (8.0.034).
I am not alone to find that bug, on my forum.
Frederic
No, you are not the only one to run into this. It will be fixed in the next update.
jasonshih
Hi Steve,
after update to latest version, say 8.1-025, I still run into same situation. Will this fixed shortly? However, old version fortran compiler, say 7.1, dont have similar error msg.
BR,
J
I am told it will be fixed in an update due out in mid-April.
