Dear IFC developers,
I'm trying to compile a code with ifc 9.1.032 (em64t). I encountered some errors, which are very similar to one old post in this board here:
http://softwareforums.intel.com/ids/board/message?board.id=11&message.id=2290
I didn't get any error message while compiling with ifc 9.0.
Any suggestions?
#ifort ./para_p.f -o ./para_p.o
fortcom: Error: ./para_p.f, line 136: Unbalanced parentheses
&'" with ",I3," procs): I am the superparent. ")')
fortcom: Error: ./para_p.f, line 136: Syntax error, found ''' when expecting one of: ( ...
fortcom: Error: ./para_p.f, line 136: Syntax error, found ''' when expecting one of: ( , ; ...
fortcom: Error: ./para_p.f, line 140: Syntax error, found ''' when expecting one of: ( ...
&'" with ",I3," procs): Output --> ",A5,".")')
fortcom: Error: ./para_p.f, line 141: Syntax error, found IDENTIFIER 'UT_' when expecting one of: .EQV. .NEQV. .XOR. .OR. .AND. .LT. .LE. = .EQ. == .NE. /= .GT. > ...
&ME,nmr_mygroup,nproc,'out_'//zahlenchars(nmr_mygroup)
compilation aborted for ./para_p.f (code 1)
Here is the source code of para_p.f:
C This is line 130.
C ==--------------------------------------------------------------==
do i=1,nmr_threads
if (ME.eq.parents(i)) then
if (nmr_superparent) then
write (6,'("PROCESSOR ",I3," (GROUP ",I1,'//
else
close(6)
open(unit=6,file='out_'//zahlenchars(nmr_mygroup))
endif
endif
call my_sync(nmr_supergroup)
enddo
C This is line 149.
cheers,
Rex
p.s. I'm sorry the html format above is too awkward, please see the error message and source code in the log file below.
Message Edited by Pi2002 on 06-03-200603:22 AM
tim18 wrote:
It's difficult to do anything with this, if you don't supply a working example. Did you try ifort 9.1.033 yet?
Well, I just tried the evaluation version of ifc, and 9.1.032 is the latest version I could find in your website yet.
P.S. Please find the code I tested below.
Until that is fixed, it should be possible to work around it by using // without going so far beyond the f77 standard limitations. You would have to declare a string to receive the full concatenated string, and use that string in the write. I can't check whether 9,1,033 fixed the bug for your case unless you make the case complete.
ps. I just could not logon on the Intel Premier Support website:
https://premier.intel.com/
The brower redirected me to:
http://or1grebe.cps.intel.com/scripts-util/404.asp?Redirect=Y
Maybe that's the problem of my proxy, I'll try again later.
Message Edited by Pi2002 on 06-08-200607:58 AM
ifort -c nmr_para_p.f
ifort -xW -c nmr_para_p.f
A few odd details (besides 5 unused declared variables):
Your Cray pointer usage seems to be agreeable to several compilers.
ifort doesn't mention the possibly un-initialized myfirst.
ifort em64t linux appears to be more confident about data alignments than ifort 32-bit Windows, so uses several instances of parallel SSE2.
The problem you mention with access to Premier is usually occasioned by cookie usage. You may have to delete all cookies from intel.com, possibly prior to each login. I have been prevented at times from logging into premier while logged into the forum, and then must close my browser (which then automatically deletes cookies) and start it again. The premier site administrators haven't documented exact expected cookie treatment settings, to my knowledge. About a month ago, a number of internal URL paths were changed, such that they can be broken by using paths stored in cookies. The site became easier for me to use on linux, with more than one browser, than on Windows.
Well, it runs a bit slower than the 9.0.031 version in my case, I have used PGO and -O3 level optimizations. Beside of the new CPUs support, what's the main optimization update between ifort 9.1 version and the 9.0 version?
http://www.intel.com/cd/software/products/asmo-na/eng/compilers/flin/282048.htm#new
Well, I'm really not sure about this and could not do such a test. That's why I posted a topic previously on this board here:
http://softwareforums.intel.com/ids/board/message?board.id=11&message.id=3895
Thanks again!
Rex
