29648 Discussions
Error for binary operation involving polymorphic variables
Christopher_M_
I have found that the following code (which compiles with gfortran) produceses an error with ifort 17.0.1.
module test_mod
  implicit none
  type, abstract :: bin_op_type
  contains
    procedure(bin_op), deferred :: is_equal
    generic :: operator(==) => is_equal
  end type bin_op_type
  abstract interface
     logical function bin_op(this,other)
       import :: bin_op_type
       class(bin_op_type), intent(in) :: this, other
     end function bin_op
  end interface
  type, extends(bin_op_type) :: example_type
     real :: contents
  contains
    procedure :: is_equal => example_is_equal
  end type example_type
contains
  logical function example_is_equal(this,other)
    class(example_type), intent(in) :: this
    class(bin_op_type), intent(in) :: other
    example_is_equal = .true.
  end function example_is_equal
end module
module dependency
  use test_mod
  implicit none
contains
  subroutine bug_example(obj1,obj2)
    class(example_type) :: obj1
    class(bin_op_type)  :: obj2
    logical :: result
    result = (obj1 == obj2) !This compiles
    result = (obj2 == obj1) !This doesn't
  end subroutine bug_example
end module
It produces the following error message:
binary_op.f90(44): error #6355: This binary operation is invalid for this data type.   [OBJ2]
binary_op.f90(44): error #6355: This binary operation is invalid for this data type.   [OBJ1]
compilation aborted for binary_op.f90 (code 1)
Kevin_D_Intel
Thank you for the convenient reproducer. Our apologies for the additional problem. I escalated this to Development and inquired about any possible work around.
(Internal tracking id: DPD200417363)
