Error in compiling
Deleted_U_Intel
Sorry. Now I put in correct place.
When I try to compile using fortcom, this message appears. I installed using RPM files (from INtel site).
Intel Fortran Compiler for 32-bit applications, Version 8.0 Build 20031016Z
Copyright (C) 1985-2003 Intel Corporation. All rights reserved.
Compiler driver / backend version mismatch: unset != 800
Be sure compiler driver and backend programs are in the same directory.
Please report product problems to Intel Premier Support.
Lorri_M_Intel
Hi -
Lorri_M_Intel
Hi -
Could you post the command you used to compile please? It sounded like you tried to use fortcom directly.
Really, you need to use the driver (ifort) so that all the correct switches are set up correctly in the invocation of fortcom.
- Lorri
Message Edited by Lorri_Menard on 01-23-2004 10:19 AM
