29653 Discussions
Error in initializing pointer with optimization option (-O2)
Heo__Jun-Yeong
Hi, I'm working on the code that constructs CSR format array using linked list.
I followed the book Ed Akin - Object-oriented programming via Fortran 90-95 (2003)
module mCSR
        implicit none
        integer, parameter, private :: DBL = kind(0.d0)
        Type :: z3CSR
            integer :: nrow, ncol, nval
            integer, dimension(:), allocatable :: ia, ja
            complex(DBL), dimension(:), allocatable :: a
        end type z3CSR
        Type, public :: zcompCSR
            integer :: col
            complex(DBL) :: val
        end type zcompCSR
        Type :: znodeCSR
            private
            type(zcompCSR) :: comp
            type(znodeCSR), pointer :: next => null()
        end type znodeCSR
        Type :: zlistCSR
            private
            Type(znodeCSR), pointer :: first => null()
        end type zlistCSR
  contains
    subroutine z3AllocateCSR(nrow, ncol, nval, CSR)
        integer, intent(in) :: nrow, ncol, nval
        Type(z3CSR), intent(inout) :: CSR
        CSR%nrow=nrow; CSR%ncol=ncol; CSR%nval=nval
        if (allocated(CSR%ia)) deallocate(CSR%ia)
        if (allocated(CSR%ja)) deallocate(CSR%ja)
        if (allocated(CSR%a))  deallocate(CSR%a)
        allocate(CSR%ia(nrow+1), CSR%ja(nval), CSR%a(nval))
        CSR%ia(:)=0; CSR%ja(:)=0; CSR%a(:)=(0.d0,0.d0)
    end subroutine z3AllocateCSR
    subroutine z3DeallocateCSR(CSR)
    end subroutine z3DeallocateCSR
    subroutine zAllocateLinkedList(head)
        type(zlistCSR), intent(inout) :: head
        allocate(head%first)
        nullify(head%first%next)
    end subroutine zAllocateLinkedList
    subroutine zInsertInOrder(comp, head, lnew)
        type(zcompCSR), intent(in) :: comp
        logical, intent(out) :: lnew
        ! local
        type(znodeCSR), pointer :: previous, current
        lnew = .False.
        previous => head%first
        current => previous%next
        do while (associated(current))
            if (comp%col.LT.current%comp%col) exit
            if (comp%col.EQ.current%comp%col) then
                current%comp%val = current%comp%val + comp%val
                nullify(previous, current)
                return
            end if
            previous => current
            current => current%next
        end do
        lnew = .True.
        allocate(previous%next)
        previous%next%comp = comp
        previous%next%next => current
    end subroutine zInsertInOrder
    subroutine z3FillInCSR(heads, CSR)
        type(zlistCSR), dimension(:), intent(in) :: heads
        type(z3CSR), intent(inout) :: CSR
        ! local
        type(znodeCSR), pointer :: current
        integer :: i, icount
        CSR%ia(1) = 1; icount = 0
        do i = 1, CSR%nrow
            current => heads(i)%first%next
                icount = icount + 1
                CSR%ja(icount) = current%comp%col
                CSR%a(icount) = current%comp%val
            end do
            CSR%ia(i+1) = icount + 1
        end do
        nullify(current)
    end subroutine z3FillInCSR
    subroutine zDeallocateLinkedList(head)
        ! local
            previous%next => current%next
            deallocate(current)
        end do
    end subroutine zDeallocateLinkedList
end module mCSR
The code simply works like below:
program test
        use mCSR
        implicit none
        integer, parameter :: ncomp = ! known value for test
        integer, parameter :: nrow =  ! known value for test
        type(zlistCSR), dimension(:), allocatable :: heads
        type(z3CSR) :: CSR
        integer :: i, irow, icount
        logical :: lnew
        allocate(heads(nrow))
        do i = 1, nrow
            call zAllocateLinkedList(heads(i))
        end do
        open(1, file='comp.dat')
        icount = 0
        do i = 1, ncomp
            read(1,*) irow, comp%col, comp%val
            call zInsertInOrder(comp,heads(irow),lnew)
            if (lnew) icount = icount + 1
        end do
        close(1)
        call z3AllocateCSR(nrow, nrow, icount, CSR)
        call z3FillInCSR(heads, CSR)
        do i = 1, nrow
            call zDeallocateLinkedList(heads(i))
        end do
        deallocate(heads)
        ... (use CSR for PARDISO or etc)
end program test
When I complied the codes with the option:
 ifort -fpp -m64 -warn all -check all,noarg_temp_created -traceback -stand f03 -fstack-security-check
the program works fine.
But when I compiled the codes with the option:
ifort -O2 -qopenmp
all the CSR%ja = 0, and CSR%a only has the imaginary part of the input.
I found that the solution is not to initialize the pointer 'next' in the type 'znodeCSR'.
i.e.) modify
  to
But I can't figure out why.
Could you me know why I should not initialize the pointer 'next' and
why the initializtion of the pointer 'first' in 'zlistCSR' is okay?
* my computer system is centOS 7, and oneAPI version is 2022.1.1.119
Labels (3)
Barbara_P_Intel
Are there OpenMP directives in your code? If not, why did you use -qopenMP. There are several issues that are fixed when compiling with -qopenmp. Please try the latest compiler release that is part of oneAPI HPC Toolkit 2023.0. The ifort version is 2021.8.0.
If the latest compiler doesn't fix your issue, can you upload the complete reproducer?
When you don't specify -O[0123] the default is -O2.
