Error in opening the compiled module file
hyun_no_N_
 when it is compiled, it shows many errors such as:
mpif90 -c -O3 -ip -convert big_endian -assume byterecl -heap-arrays -r8  -I/usr/local/netcdf/412_intel11/include -DOASIS3 -I/data14/hhno/speedy_nemo/speedy_nemo/Linux_MPI1/build/lib/psmile.MPI1  -I/data14/hhno/speedy_nemo/speedy_nemo/Linux_MPI1/build/lib/clim.MPI1 -I/data14/hhno/speedy_nemo/speedy_nemo/Linux_MPI1/build/lib/mpp_io print_obs.pp.f90 -o print_obs.o print_obs.pp.f90(3): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [DATE_UTILS]    USE date_utils
I use MPICH v1.2.7(/usr/local/mpich1/intel11) and Netcdf v4.1.2 (/usr/local/netcdf/412_intel11)
What are the possible problems?
Thank you in advance.
Hyun-ho
TimP
It seems that you have a USE referring to a .mod file which isn't found on your include paths. Among possible reasons: netcdf wasn't built first and installed in the include path you quote date_utils.mod wasn't built with the same compiler version as the one which is trying to read them ( check mpif90 -V and ifort -V )
hyun_no_N_
Thank for your comment. I checked mpif90 -V and ifort -V. compiler version is same. But I got another error code. mpif90 -c -O3 -ip -convert big_endian -assume byterecl -heap-arrays -r8 -I/usr/local/netcdf/412_intel11/include -DOASIS3 -I/data14/hhno/speedy_nemo/speedy_nemo/Linux_MPI1/build/lib/psmile.MPI1 -I/data14/hhno/speedy_nemo/speedy_nemo/Linux_MPI1/build/lib/clim.MPI1 -I/data14/hhno/speedy_nemo/speedy_nemo/Linux_MPI1/build/lib/mpp_io enactdata.pp.f90 -o enactdata.o enactdata.pp.f90(2): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [TOOLSPAR_KIND] USE toolspar_kind ------^ enactdata.pp.f90(17): error #6683: A kind type parameter must be a compile-time constant. [DP] REAL(KIND=dp) , DIMENSION(:) , POINTER :: p_lam !: latitude enactdata.pp.f90(578): error #6404: This name does not have a type, and must have an explicit type. [DP] & -180.0_dp)/=nf90_noerr) THEN -----------------^ enactdata.pp.f90(578): error #6975: A kind-param must be a digit-string or a scalar-int-constant-name [DP] compilation aborted for enactdata.pp.f90 (code 1) gmake[1]: *** [enactdata.o] Error 1 gmake[1]: Leaving directory `/data14/hhno/speedy_nemo/speedy_nemo/nemo_build/ifort_oasis3/opa.ORCA2_OASIS3.1.1' gmake: *** [tools] Error 2 Should I add include path in *.F90 ? I will very appreciate if you give me some advice.
mecej4
The file toolspar_kind.mod must exist before you can compile any sources that USE that module. 1. Check that the file that contains the source code of the module has been compiled. 2. Check that the resulting module file is accessible through the INCLUDE path list.
