29618 Discussions
Error in opening the compiled module file
Mike896
I have a project which will create static library. I use it a lot and it was ok.
Now, when it is compiled, it shows many errors such as:
error #7002: Error in opening the compiled module file. Check INCLUDE paths.
I rebuild the solution. Errors are still the same.
The source files are all put in a directory. So I think I don't need to set the Additional Include Directories.
What are the possible problems?
Thank you in advance.
Mike
Mike896
Quoting - Mike896
Mike
It's very strange.
That library worked well before. Now, I add a subroutine.
Then it has this error.
I comment the added subroutine.
Rebuild it. There is no error.
After uncommentting it, there is no error again.
How come?
Mike
Jugoslav_Dujic
Valued Contributor II
Quoting - Mike896
It's very strange.
How come?
Mike
I don't have enough data to debug the problem, just a couple of hints:
  • The message "Error in opening the compiled module file" means that the compiler can not locate the .mod file. The Foo.mod file is expected when compiler encounter "USE Foo" in a source file.
  • That message is normally accompanied with a module name (although I didn't check in 11.0) -- is it?
  • When you use MODULEs and build them in a static library, you (usually) also need to distribute the .mod files along with the lib, in order to build the .exe. (Or give the compiler the appropriate INCLUDE path). Is that the caes, or you're encountering the problem while building the .lib itself?
If you don't use MODULEs at all, you might have encountered a compiler bug. A wild guess for a workaround is that you remove /gen-interfaces (Fortran/Diagnostics) and /check-interfaces, but that's just a wild guess. You should give us some more data to work with.
Mike896
Quoting - Jugoslav Dujic
Thank you very much for your reply, Jugoslav. Your informations are always helpful.
The problem now I figure out is due to cyclic dependency, as I also encounter repeated compiling even without any modification of programs. I have also posted in http://software.intel.com/en-us/forums/showthread.php?t=62386.
Mike
wmaquite
I'm getting a similar error that I haven't been able to solve. I'm just trying to check that the IMSL Library was properly installed following http://www.vni.com/tech/imsl/gettingStarted/using/use_for_win.php
But I get this Error:
Error 1 error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LSARG_INT]
I have added the \IA32\include\DLL to Project->Properties->ConfigurationProperties -> Fortran->General, "AdditionalIncludeDirectories"
How can I prove that such path is properly set?
Thank you,
Jugoslav_Dujic
In the additional include directory, there should be a file LSARG_INT.mod -- is it there?
Do not use in the Visual Studio settings - that's a placeholder for the actual path. You may be able to use $(FNL_DIR) instead. I prefer to add this under Tools > Options > Intel Visual Fortran > Compilers. Add the path to the IMSL libraries here too.
I suggest following the instructions in the Intel Fortran documentation under Building Applications > Using Libraries > Using IMSL
wmaquite
I actually added it as C:\Program Files\VNI\imsl\fnl600\IA32\include\dll in Includes and as C:\Program Files\VNI\imsl\fnl600\IA32\lib in the Libraries.
I also followed the instructions as you suggested. Not even adding the imsl.lib and imsl_dll.lib libraries in the Source files helped.
I still get the same error.
Thank you,
wmaquite
Hi Jugoslav. Yes, that files is there.
Thank you,
Please attach the build log for the failed build.
wmaquite
Here it is.
Thanks for your help,
Will
When you entered the path for the Include files, you inserted a blank at the beginning. Take it out.
wmaquite
Oh thank you. Now the example works.
sawado
Hello everybody,
I have a similar problem. I want to use fftw3 library in a fortran program. I downloaded the DLLs from fftw.org and I extracted the .lib files with:
lib /def:libfftw3-3.def
My code is similar to:
[bash]
    Program bFFTW
   ! use libfftw3
    !DEC$ OBJCOMMENT LIB:'libfftw3.lib'
    integer :: Num,jres,L
    double precision :: AIN(10**6),ATIME(20)
    double complex :: AOUT(10**6)
     CALL cFFTW(AIN,AOUT,N)
    Contains
        subroutine cFFTW(Ain,Aout,N)
       !  use libfftwf
         double precision in,ain
         dimension in(N),ain(10**6)
         double complex out,aout
         dimension out(N/2 + 1),aout(10**6)
         integer*8 plan
         integer I
         DO I=1,N
            in(I)=AIN(I)
         END DO
         call dfftw_plan_dft_r2c_1d(plan,N,in,out,FFTW_ESTIMATE)
         call dfftw_execute_dft_r2c(plan, in, out)
         call dfftw_destroy_plan(plan)
       end subroutine cFFTW
   end program bFFTW
     [/bash]
When I try to compile it with ifort, I get the message :
[bash]bFFTW.F90(4) : Error: Error in opening the compiled module file.  Check INCLUDE
paths.   [LIBFFTW3]
    use libfftw3
--------^[/bash]
Can you help me either to add properly the libs in Visual Studio 2005 or to compile and link it with intel fortran 9.1?
You need to compile the Fortran source that defines module LIBFFTW3. I assume it is included in the distribution. Simply add that source to your project. It has nothing to do with "libs".
sawado
Thanks for your answer. Actually there is no fortran source for the fftw code since it has been developped in C and compiled to produce some DLLs (http://www.fftw.org/install/windows.html). I want to link my fortran program to those libraries and I failed to make it work.
If that's so, then what prompted you to add a "use libfftw3" to your source?
I will comment that if the library is written in C and has lowercase names, you will need some set of declarations of the routines. I presume that's what's supposed to be in a libfftw3 module.
sawado
Because, usually in Fortran, The USE statement is used to include an external library. Is there another way to do it? If, I comment the Use statement and let just this:
[bash]!DEC$ OBJCOMMENT LIB:'libfftw3.lib'[/bash]
I get this error during the compilation:
[bash]bFFTW.obj : error LNK2019: unresolved external symbol _DFFTW_PLAN_DFT_R2C_1D ref
erenced in function _MAIN__
bFFTW.obj : error LNK2019: unresolved external symbol _DFFTW_EXECUTE_DFT_R2C ref
bFFTW.obj : error LNK2019: unresolved external symbol _DFFTW_DESTROY_PLAN refere
bfftw.exe : fatal error LNK1120: 3 unresolved externals[/bash]
How do I make Fortran understand the lower case subroutines names? That may explane the error above.
The USE statement references a Fortran module. It is true that many libraries provide modules to declare interfaces to their routines, but that is not universal.
There are several approaches you can take, but let's start with the simplest. Add these lines in your declaration section:
!DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d
!DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_execute_dft_r2c" :: dfftw_execute_dft_r2c
!DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_destroy_plan" :: dfftw_destroy_plan
Now I don't know if these routines need anything else, such as passing some arguments by value. If so, that would require something more. You'll know that you have this issue if you get an access violation on a call.
sawado
Thank you for your answer,
I have tried this
[bash]Program bFFTW
!DEC$ OBJCOMMENT LIB:'libfftw3.lib' !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_execute_dft_r2c" :: dfftw_execute_dft_r2c !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_destroy_plan" :: dfftw_destroy_plan [/bash]
And I get this error:
[bash]bFFTW.F90(6) : Error: Only a function or subroutine subprogram may have the !DEC
$ ATTRIBUTES directive DECORATE specifier.   [DFFTW_PLAN_DFT_R2C_1D]
 !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d[/bash]
Sigh. Try this instead:
!DEC$ ATTRIBUTES ALIAS:"_dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d
!DEC$ ATTRIBUTES ALIAS:"_dfftw_execute_dft_r2c" :: dfftw_execute_dft_r2c
!DEC$ ATTRIBUTES ALIAS:"_dfftw_plan_destroy_plan" :: dfftw_destroy_plan
